Introduction: Spatula Handle Assist
The Spatula Handle Assist is an innovative attachment designed to change the way you work with a spatula, making cooking and baking more accessible and enjoyable for everyone. Handle Assist, made with precision and care, is not just an accessory; it's a solution built with inclusivity in mind.
Whether you face mobility, dexterity or grip strength challenges, Handle Assist offers a seamless and ergonomic solution. Its thoughtfully designed design ensures a comfortable grip, providing stability and control while easily maneuvering the paddle. Say goodbye to problems and welcome newfound confidence in the kitchen.
But Handle Assist isn't just about functionality – it's about empowerment. Removing barriers to cooking allows individuals of all abilities to unleash their creativity and express themselves through the joy of culinary creation. From flipping pancakes to cooking fried rice, Handle Assist lets you handle any recipe with grace and efficiency and can be fit into any form of spatula to add functionality and use.
Join the culinary revolution and experience the freedom of cooking without restrictions. With Handle Assist, every kitchen effort becomes an opportunity for empowerment and pleasure. Let's cook together inclusively.
- Kitchen utensil with a hole in the handle
- 3d printer with at least 23 grams of PLA
- 2 stainless nuts and bolts with one being slightly smaller than the size of your spatula hole handle
Step 1: Download the Stl and Size Fitting
Download the STL and correct the size of the hole to the size of the spatula depression and a hole on the top of the handle adjusted to the nut and bolt you have on hand. I found that a 6mm hole fits most cooking utensils. If you do not have a hole in the utensil, create both holes corresponding to the bolt on hand.
Step 2: Application
Import it onto the Cura Lulzbot application or your preferred 3d printer app of your choosing. Make sure the infill density is set to 10% with a 10mm infill line distance and generate the support necessary for the handle form and structure. The 3d printing process is going to take around 1 hour and 25 minutes and uses around 23 grams of PLA.
Step 3: The Support
Break and tear away the support and sand the surface.
Step 4: Drilling TheTop Part of the Handle
Drill one side of the handle without the hole to the spatula of your choosing, make sure the hole of the handle corresponds with the spatula as well as center the drill hole with the handle hole that you have made for the other side
Step 5: Bolting the Spatula
Use an around 6mm thick stainless steel nut and bolt to secure the handle to the spatula. When testing, I found that not using a stainless steel nut and bolt will result in the attachment creating rust and overall contamination while cooking.
Step 6: Enjoy!
Enjoy your new handle-assist spatula!
This is an entry in the
Engineering in the Kitchen - Autodesk Design & Make - Student Contest
