Introduction: Super Skateboard
This time, I used the fusion 360 3D modeling software to search the skateboards on the Taobao, Jingdong and other websites to find out the size and weight of the skateboard.
Skateboard rendering adopts the traditional Chinese ancient style to render, which is an innovation of appearance.
Step 1: Wheel and Bearing Structure
Create a sketch on the X-Y plane to create the wheels and bearings of the scooter.
Step 2: Structure of Sliding Plate Surface
Build eight screws and eight nuts, and use the punching function on the sliding plate .then make the screw hole and place the screw nut, and guide the screw nut to connect with the sliding plate.
Step 3: Structure of Screw and Nut
Step 4: Shock Absorption and Support Frame at the Bottom of Sliding Plate
The shock absorption and support frame at the bottom of the sliding plate are constructed and assembled on the bottom plate of the sliding plate.
Step 5: Construction of Wheel Axles
Two axles are built to refine the dimensions of both ends of the axle so that the bearing can be installed on the axle.
Step 6: Wheel Assembly
Assemble the four wheels on the axle, adjust the distance so that the center of the wheel is aligned with the outside of the sliding plate surface.
Step 7: Inserting a Map on the Scooter
Respectively insert the map on the skateboard surface, wheel and axle to make the skateboard look good.
Step 8: Render the Skateboard and Change the Material of Each Part.
Render the skateboard and change the material of each part.
