Introduction: Survival Kit in a Floss Container
For todays instructable I will show you how to make a survival kit in the unassuming, tiny floss container.
Here goes.....
Step 1: Gather Materials
What you need:
-roll of scotch tape
-small fish hook
-fish line
-razor blade
-matches
-striker
-safety pin
-wire
-electrical tape
-2 rubber bands
-water purification tablet
-dental floss container
-2 pliers
Step 2: Fish Line, Saw, and Razor Blade
To get these items you need to go through other steps to make them fit.
1. Saw
I got my mini saw from the end of a roll of scotch tape. I easily cut it to the right shape with scissors and put it in the kit.
2. Razor Blade
To get the razor blade to the right size I used the two pliers. With one I held the blade where I wanted it to snap and with the other broke it off so that it became the right size.
3. Fish Line
The fishing line was simple. I cut out 2 ft and then folded it over itself so it was the right size, and then rapped it in tape to keep it together.
Step 3: Container
For the floss container I removed the floss and took out the pegs it was distributed on by simply snapping them off. I then removed the stickers and the metal thing used to cut the floss. However, if you want it to look unassuming, keep the stickers and metal thing on amd glue a little floss in the inside and feed it through the top.
Step 4: Everything Else in the Kit
The rest if the items are:
-6 inches rolled duct tape
-2 rubber bands
-safety pin
-matches cut to right length
-striker for matches
-wire
-fish hook
Step 5: Packing
I started by putting everything flat at the bottom and rapping the fish line around the outside, the fitting everything in after that.
Thank you for reading my instructable! Please hit that heart button, follow and check out my other instructables! God bless
