Introduction: THE DIRECT DRIVE AND ORBITER V1.5
This is an direct drive that supports ender3, ender 3S, ender 3 V2, ender 3 PRO, CR-10, CR-10 S5, CR-20, CR-10 MINI, CR-10 S4, CR-10S 3D printer.
video(make): https://youtu.be/EwfdDj4dOdA
The Ender 3 direct drive weight: about 259g (Including the stock hotend, cooling fan, the E motor extruder).
***Nozzle-to-Probe offsets { X, Y, Z }
#define NOZZLE_TO_PROBE_OFFSET { -28.75, -9, Z }
***Features:
1 Printing TPU is more convenient and faster;
2 very light weight;
3 Assembly and disassembly is very convenient(Just need to turn one screw);
4 Support Orbiter extruder: https://www.thingiverse.com/thing:4725897
5 Can also be used as a Long-Distance remote extruder;
6 Support BLtouch and 3Dtouch;
***Bill of Materials:
Note: Considering that some people don't have the Insert Nut Tool, this version has two, one of which only requires a normal nut to assemble.
***The source file is also there, if you have an idea, you can edit it.
Version A M3 Knurled Brass Nut:
1 2 prints(Ender3-M3 Knurled Brass Nut.STL);
2 M3 X 6 Socket Head Cap(2);
3 M3 X 8 Socket Head Cap(3);
4 M3 X 12 Socket Head Cap(2);
5 M3 X 35 Socket Head Cap(1);
6 M3 Hexagon nut(1);
7 M3 Knurled Brass Nut(M3X4X4.5mm)(6);
8 3010 fan;
9 5015 fan;
10 The Orbiter V1.5 Extruder;
11 Teflon tube(64.5mm);
Version B M3 Square Thin Nut:
1 1 2 prints(Ender3-M3 Square Thin Nut.STL);
6 M3 Square Thin Nut: 5.4mm X 5.4mm X 1.8mm(5);
7 3010 fan;
8 5015 fan;
9 The Orbiter V1.5 Extruder;
10 Teflon tube(64.5mm);
Step 1: Print 2 Printed Parts
If there is any fluff, you can use a lighter to remove it.
Step 2: Insert the Nuts
I used a soldering iron, heated to 330℃.
Step 3: Install the 5015 Turbo Fan
Note: Before installing the 5015 Turbo fan, use needle nose pliers to reduce it into a V shape. Use M3X35 screws to fix.
Step 4: Install the 3010 Fan and Fan Duct
The 3010 fan is fixed by the fan duct, and then use M3X12 screws to fix the fan duct.
Step 5: Install the BLTouch or 3D Touch
Fix with M3X6 screws.
Step 6: Replacing the Teflon Tube
Before replacing the Teflon tube, you need to preheat the hotend to 200°C.New Teflon tube length is 64.5mm
Step 7: Soldering the Fan
Remove the original fan first, then solder the new fan.Pay attention to the positive and negative.
Step 8: Install the Frame
The right side is fixed by inserting the card, and then fixed with an M3X8 screw.
Step 9:
The Orbiter V1.5 extruder is fixed with M3X8 screws.
Step 10: Soldering the Stepper Motor Wires
Wiring as shown.
Step 11: Modify the E Steps to 690
remember to save.
Step 12: Modify the E Drive Current to 0.45V
Measure with a multimeter.
Step 13: Replacing the Spool Holder
Use M5X16 screws to fix.
