TMC2208 UART on BigTreeTech/BIQU SKR V1.1, V1.3, and V1.4 Controllers
Introduction: TMC2208 UART on BigTreeTech/BIQU SKR V1.1, V1.3, and V1.4 Controllers
So.. You got yourself a BigTreeTech/BIQU SKR v1.1, v1.3, or v1.4 controller board, and you want to use TMC2208 driver modules on it, in UART mode, with Marlin? It's not difficult to set up.
Note: this Instructable is meant for the general-use LPC1768-based SKR boards -- it does not apply to the "Pro", "Mini", or any of the other models aimed at specific printer brands or use cases.
Prerequisites:
  • You'll need to know how to do a little basic soldering.
  • You'll want to have good lighting, and a decent magnifier lamp.
  • You'll need some basic skill in using a text editor, and understand how to compile Marlin. Try their official guide. It's aimed at Re-ARM, but the process is the same for SKR boards.
  • You'll need to make sure you have the PlatformIO TMCStepper library installed.
  • Your PlatformIO framework-arduino-lpc176x platform module must be fairly recent as well.
  • You'll need Marlin 2.0.x, preferably the bugfix-2.0.x branch, from their official repository.
You may not necessarily be able to just use any random download/snapshot of the Marlin source tree, so be ready to play with different commits. This will put you on that branch, even with 2.0.4.1-release:
git clone https://github.com/MarlinFirmware/Marlin.git
cd Marlin
git checkout bugfix-2.0.x
git reset --hard 484e1a62
When you're sure Marlin and PlatformIO are ready, go ahead and load your Marlin configs into your favorite editor or IDE (you'll do the necessary tweaking later in this Instructable).
If you're using the SKR v1.1 and have an LCD connected, please disconnect it prior to following this guide, just to avoid any possible interference. You can plug it back in later.
All users:
  • Solder
  • A fine soldering tip would be a very good idea also.
SKR v1.1 users only:
  • Some female Dupont connectors (two per driver module). You can find these in a lot of older electronics -- I got mine from old PC cases. You probably have some in your junk box.... er, you DO have a junk box, right?
  • If possible, some single-pin Dupont connector housings for the above (one per driver module)
  • Some appropriate wire (anything will do as long as it's easy to work with)
  • Heat shrink tubing (2 to 3 millimeter size, 2:1 shrink ratio or better, as long as it fits)
SKR v1.3 or v1.4 users only:
  • Some shunt jumpers (one per driver module). I refer to the little caps that people routinely call "jumpers", used to temporarily, electrically bridge two pins together. To avoid confusing terms, I'll call these "shunts", as distinct from the pins they go on ("headers", but sometimes also called jumpers), or the pads on your driver modules that you'll be soldering on (yet again, also called jumpers)
Step 1: Modify Your Driver Modules...maybe
In most modern TMC2208 driver modules, there is an empty three-pad jumper present.
In most cases, that jumper is next to the middle two pins on the En/Step/Dir header. One such example is the white FYSETC module pictured above (main image).
In one variant made by Eryone (the amber board above, top-right), this three-pad jumper is not in the middle like usual, but instead is positioned way over near one edge where the potentiometer would normally be found, next to the three diagnostic holes, and aligned parallel to the edge of the driver module (and there's a two-pad jumper on the other end next to a resistor).
In most any kind of electronics, when you see a 3-pad jumper like this, usually you would short the middle pin to one end or the other, if anything at all. In driver modules like these, which pad should be shorted to to the middle technically depends on what SKR version you'll use the module on. But, the way driver modules are used allows us to make it simple: just solder-bridge all three pads together.
This connects the TMC2208 chip's PDN/UART signal to both the PDN pin on the module's header, and to the unused pin next to it. This configuration will work on pretty much all controller boards regardless of make or model, so long as the board still has a standard MS1-3 config jumper block between the driver module's headers, and can be configured or hacked to use UART mode. That includes the SKR v1.3 and v1.4 as well, though this is NOT needed on those.
Some modern modules have a three-pad jumper pre-configured for UART, along with three pins sticking up from the top.
BigTreeTech's v3.0 driver (the black PCB above, bottom-right) is an example of this type. The middle of those pins provides a convenient place to pick up the PDN/UART signal (the others are the NC and Clock pins).
On the bottom, there is the usual three-pad jumper (highlighted with a red ellipse), but one pair of pads is bridged with a 0-ohm link (which resembles a tiny surface-mount resistor, see the green box).
If you have these modules, you need not do any soldering, nor any other modifications. They're already set up and ready to use in UART mode on basically any brand and make of controller that can handle it (either by getting the PDN/UART signal from the aforementioned middle pin, or via already-present circuitry in the controller).
In some modern modules, the 3-pad jumper is pre-configured for UART, but there are no top-side pins.
Such drivers may either come with their PDN/UART jumper already solder-bridged for you, or there may be a thin trace connecting two pads, or they may have a 0-ohm link as with the above BTT modules.
If you'll be using them on an SKR v1.1, just solder-bridge the jumper's middle pad to the unconnected side. If the jumper has a 0-ohm link but it falls off while soldering, let your vacuum have it :-) and just solder-bridge all three pads together. As with the empty-three-pad-jumper kind mentioned above, you can do this soldering regardless of the SKR version you're using, if you want, but it's only needed on the v1.1.
Some older modules just have a two-pad middle jumper.
I have some Eryone driver of this type (the brighter-colored amber board hidden behind the "2 More Images" link above). Incidentally, they seem to be based on some old reference design, as they're basically identical to a number of other brands from the same period.
On these modules, there are at least two sets of jumper pads on the underside: one close the STEP pin, and one close to the middle two pins. There may also be a jumper on the right (assuming you're holding the module with the bottom facing you and the diagnostic holes to the right).
Solder-bridge the middle jumper's pads together.
Some driver modules have the chip and various other parts are on the top of the PCB.
On these modules, like the second black PCB above (hidden behind the "2 More Images" link), the parts aren't on the bottom side like usual. If you hold the module with the chip and such facing you, and the potentiometer and diagnostic holes to your left, there'll be one set of jumper pads on the right, and one set near the middle. There may also be a jumper on the left. There are at least two brands that put the chip and such on top, or used to in the past (Watterott and BigTreeTech prior to v3.0). In these cases, we're interested only in the jumper pads near the middle of the En/Step/Dir header.
As with the others, just use your soldering iron to bridge this middle pair of pads together. This will connect the driver chip's PDN/UART signal to the PDN pin on the driver module's header.
If your drivers have a three-pad jumper:
⬈ If you're using SKR v1.1, jump ahead to "Patch Things Up".
⬈ If you're using SKR v1.3 or v1.4, jump ahead to "Close Some Circuits".
If your driver is one of the older ones with an empty two-pad jumper (parts on bottom or top):
⬇ You have more soldering to do, so continue to the next step, "Modify Your Driver Modules (Part 2)".
Everyone else:
If your drivers have no PDN/UART jumpers, and have not been clearly and explicitly declared as being already wired for UART mode, then you must assume that they are the really old kind, and thus are NOT UART compatible.
You will not be able to use this old type of driver for this Instructable, unless you have very good soldering skills and dexterity and can safely tap into the PDN/UART pin on the 2208 chip itself.
If that's the case, STOP HERE. You'll either have to hack your way into usability, or get new drivers that can be used with this Instructable.
Step 2: Modify Your Driver Modules (part 2)
If your driver module is of the type with two pads on the middle jumper, or it has no jumper at all but comes from the factory claiming to be UART-ready, then you will most likely need to make a solder bridge on the top side of the driver module to connect the PDN pin to the unused pin next to it on the module's header. Some driver modules may not actually need this bridge, but if you've reached this step, just make the bridge anyway -- its presence won't hurt anything, and this eliminates a possible point of confusion.
This unused pin is most likely unmarked, or may be labeled "NC". As you can see on my Eryone modules, the manufacturer put the OpenHardware logo next to it.
We do this because on the controller board, that unused pin happens to be routed to the MS1-3 jumper header under the driver module, making for a convenient place to pick up the UART signal on controller boards that don't have UART support hard-wired in, without having to muck about with cutting traces or flipping pins to the top side of the driver modules.
⬇ If you're using SKR v1.1, proceed to the next step, "Patch Things Up".
⬈ If you're using SKR v1.3 or v1.4, skip ahead to "Close Some Circuits".
Step 3: Patch Things Up
For SKR v1.1 users only:
For whichever axis you're working on, remove all shunts from the board's MS1-3 config block.
You'll need to prepare some simple patch wires, with a female Dupont connector on each end.
This is single-wire UART mode, so the patch wires need no resistors or Y-splits (the heat shrink tubing in the middle of my patch wires is just a simple splice, since I re-used wires with Dupont connectors from other random, discarded electronics).
If your driver module is one of the common kind with a two-or three-pad jumper:
Only affix the the plastic connector housing to only one end of the patch wire -- leave the other connector bare.
Carefully bend that bare connector in half "backwards", to create a simple right-angle connection. By backwards I mean that once bent, you could put a really long pin through the connector part, without hitting the crimped-wire end. Add a drop of solder to the inside of the bend (the side that'll face down when plugged in) to reinforce it, and shrink a bit of heat-shrink tubing over it for insulation.
Connect the right-angle end to pin 5 of the config block on the SKR board for the axis you're dealing with (it should be clearly marked on the board next to the pin). This would normally be the MS3 signal line on drivers like the A4988 or DRV8825, but TMC2208 driver modules don't use this connection at all, so the soldering we did on the module routed the TMC2208 chip's PDN/UART signal such that we could pick it up from pin 5.
On the other hand, if your driver has the three pins sticking out of the top:
That is, if it's one of BigTreeTech's v3.0 modules with the UART jumper already bridged, or it's one that uses the same design ayway, connect one end of one your patch wire to the middle of the three pins (highlighted with a red box above).
In either case:
Whatever you connected the one end to, connect the other end of the patch wire to an appropriate GPIO pin on the SKR's AUX1 or LCD/SD/SPI header. But just where are these signals? That's explained in the next step.
Step 4: Help Marlin Make the Connection
In the above image, you'll see areas highlighted in yellow and orange, to point out specific connectors, with a few individual pins highlighted in red, green, blue, and gray. Those highlighted pins are the ones I had in mind for you to use, but there are a few more pins available on the board than you'll need for this project, so you have some leeway here.
Whatever pins you settle on, you will need to define them in Marlin to match where you intend to connect the patch wires on AUX1 and LCD/SD/SPI.
The aforementioned "leeway" can be confusing (it didn't do me any favors, to be sure), so to make it simple, I initially went with gloomyandy's pins definitions, reflected in the image above, and put the following into what is now src/pins/pins_BTT_SKR_V1.1.h, just before "LCD Controller" section (it can go anywhere):
#if HAS_DRIVER(TMC2208)
  #define X_SERIAL_TX_PIN    P2_06 // "2.6" on LCD/SD/SPI (aka AUX3)
  #define X_SERIAL_RX_PIN    P2_06
  #define Y_SERIAL_TX_PIN    P1_31 // "1.31" on LCD/SD/SPI
  #define Y_SERIAL_RX_PIN    P1_31
  #define Z_SERIAL_TX_PIN    P1_23 // "1.23" on LCD/SD/SPI
  #define Z_SERIAL_RX_PIN    P1_23
  #define E0_SERIAL_TX_PIN   P0_03 // "RX" on AUX1
  #define E0_SERIAL_RX_PIN   P0_03
#endif
If you intend to use an LCD such as RepRap Discount Full-Graphic 12864, the above pins will probably not work for you -- they didn't for me once I put a 12864 on the machine. But, since I only intend to use one extruder and I don't need to use "E1" to drive anything else (some people use it to drive a second Z motor), I was able to just use some of that driver slot's unused signals, via the little 4-pin male header next to it. Of course, one must leave the E1 driver slot empty (some people may habitually use it to hold a spare, unused driver module). Here's the configuration I settled on for that arrangement (note that this differs from the above image):
  #define X_SERIAL_TX_PIN    P0_10 // E1 "EN"
  #define X_SERIAL_RX_PIN    P0_10
  #define Y_SERIAL_TX_PIN    P0_01 // E1 "STP"
  #define Y_SERIAL_RX_PIN    P0_01
  #define Z_SERIAL_TX_PIN    P0_00 // E1 "DIR"
  #define Z_SERIAL_RX_PIN    P0_00
  #define E0_SERIAL_TX_PIN   P2_06 // "2.6" on LCD/SD/SPI
  #define E0_SERIAL_RX_PIN   P2_06
#endif
If you use this latter configuration, you must also open src/pins/pins_BTT_SKR.h. You've got some tweaking to do there. Look for this section:
#ifndef E1_STEP_PIN
  #define E1_STEP_PIN      P0_01
#endif
#ifndef E1_DIR_PIN
  #define E1_DIR_PIN       P0_00
#endif
#ifndef E1_ENABLE_PIN
  #define E1_ENABLE_PIN    P0_10
#endif
For old versions of Marlin that are still new enough to support the SKR v1.1, look for these lines instead:
In both cases, simply comment-out the entire section by putting /* above the first line, and */ below the last line, or you can put // at the start of every line.
Finally, open Configuration_adv.h and change this setting:
#define SDCARD_CONNECTION LCD
You should be able to just find and uncomment that line (when commented-out, the default is to disable the LCD's SD card reader).
There may be other pins on the SKR v1.1 that can be used, but I don't know for sure what else you could try, so if the above options won't work, I'll have to leave it as an exercise to the reader to choose appropriate pins to keep the LCD, SD, and 2208's out of each other's way. Comments welcome!
⬈ Skip the next step and jump ahead to "Give Your Board Some Intelligence".
Step 5: Close Some Circuits
For SKR v1.3 or v1.4 users only:
These boards already have the internal circuitry needed to route the UART signals between the LPC1768 and the driver modules, and Marlin already has the proper pins definitions for them. So, the patch wires and pins.h changes mentioned in previous steps (that you hopefully skipped!) are not necessary to use TMC2208's with these boards.
On these boards, the MS1-3/SPI config block consists of four sets of three-pin jumper headers. On both boards, you must clear the config block of all shunts (many boards normally come with a bunch already plugged in), for each driver slot that'll hold a TMC2208 driver module.
Then...
On the v1.3:
Simply plug shunts into the red UARTX, UARTY, etc. headers located next to (and outside of) the driver module headers on the SKR board. You can see them in the image above, left.
If you have any shunts plugged into the red diagnostic header on the right, next to the two X end stop connectors, remove those, too (this header is not shown in the above photo).
On the v1.4:
On these boards, you'll be using a couple of pins on the config block that you just cleared-out:
Put a single shunt back onto the left two pins of the second row from the red header. The image above, on the right, should make it clear, with the shunt shown in white for clarity.
Step 6: Give Your Board Some Intelligence
All users:
You will of course need to configure Marlin to be able to do its job, if you have not done so already. For brevity, I've omitted most settings that are commented-out or are either specific to my bot alone, or which don't apply to my bot at all. That is, I've tried to include only the stuff that everyone will need.
Start with these basic settings for Configuration.h to get it to at least talk to your PC properly:
#define SERIAL_PORT -1
//#define SERIAL_PORT_2 -1
#define BAUDRATE 250000
(note that the second serial port is commented-out)
You can use whatever baud rate you want that works with your PC/OS, from the list of suggestions just above that option in the config (not shown here). Faster is generally better, up to a point.
Among those Configuration.h settings, you must set your motherboard type as well. In all cases:
#define MOTHERBOARD   BOARD_BTT_SKR_V1_x
Where "x" is 1, 3, or 4, matching your board version.
After that, add whatever other configuration you need that's specific to your printer, i.e. thermistor type, temperature limits, motor steps/mm, speed and acceleration limits, build volume, end stops, and so on.
Step 7: Configure Marlin for Your Driver Modules
You'll need to set Marlin up for TMC2208 regular mode (not "STANDALONE") for whichever axes use them (I have all four; by default, Marlin expects A4988 driver modules), with appropriate settings for current, microstepping, stealthChop, spreadCycle, or Hybrid mode, and so on.
For example, in Configuration.h, I have these settings:
#define X_DRIVER_TYPE  TMC2208
#define Y_DRIVER_TYPE  TMC2208
#define Z_DRIVER_TYPE  TMC2208
#define E0_DRIVER_TYPE TMC2208
...and in Configuration_adv.h, I have these, in various places as appropriate for that config file:
#define MINIMUM_STEPPER_PULSE 1   // 0 is not recommended for TMC2208 anymore.
  #define HOLD_MULTIPLIER    0.5  // Scales down the holding current from run current
  #define INTERPOLATE       true  // Interpolate X/Y/Z_MICROSTEPS to 256
  #if AXIS_IS_TMC(X)
    #define X_CURRENT     600  // (mA) RMS current. Multiply by 1.414 for peak current.
    #define X_MICROSTEPS   16  // 0..256
    #define X_RSENSE     0.11
  #endif
  #if AXIS_IS_TMC(Y)
    #define Y_CURRENT     600
    #define Y_MICROSTEPS   16
    #define Y_RSENSE     0.11
  #endif
  #if AXIS_IS_TMC(Z)
    #define Z_CURRENT     800
    #define Z_MICROSTEPS   16
    #define Z_RSENSE     0.11
  #endif
  #if AXIS_IS_TMC(E0)
    #define E0_CURRENT    500
    #define E0_MICROSTEPS  16
    #define E0_RSENSE    0.11
  #endif
  #define STEALTHCHOP_XY
  #define STEALTHCHOP_Z
  //#define STEALTHCHOP_E
#define HYBRID_THRESHOLD
  #define X_HYBRID_THRESHOLD     150  // [mm/s]
  #define Y_HYBRID_THRESHOLD     150
  #define Z_HYBRID_THRESHOLD       3
  #define E0_HYBRID_THRESHOLD     10
#define TMC_DEBUG
Also, if you have SOFTWARE_DRIVER_ENABLE ... well... enabled, disable that option (comment-out the whole line, including the leading #define ). It doesn't do what you think it does. :-)
Step 8: Finishing-up
Install the driver modules onto their headers.
If your SKR is already able to talk to the computer (for example, if it's brand new and you're just now opening the packaging), set SKR's 5v power shunt to "USB", hook up your USB cable, and wait for the SD card to show up on your computer, and mount/open it.
If it isn't talking to the computer yet, move its SD card to your computer's own card reader, and mount it.
Backup your board's existing firmware (just copy the SD card's contents to somewhere sane), then compile and upload the firmware to that SD card. When you see firmware.bin appear in the card's folder, unmount the SD card, move it back to the SKR if necessary, then reboot the SKR board, either by pressing its reset button, or by unplugging the USB cable for a few seconds.
Do a quick communications check when it comes back up: use a host program like Pronterface, Repetier-host, etc. to send a few commands like M115 or M119 or others that don't require hooking stuff up to the SKR board, just to make sure the firmware is working. If it all looks good, you should now be done with the basic configuration.
Now power-down the SKR, wire-up your printer's main 12/24v power supply, some motors, end stops, heaters, sensors, etc., move the SKR's 5v shunt to "INT" or "VDD" (the name varies depending on which board you're using), power back up, and check that nothing's gone wonky.
Make sure UART mode is active by sending M122 from your host program. You should see something similar to this at the end of the spew in its debug console:
Driver registers:
		X	0xC0:09:00:00
		Y	0xC0:0A:00:00
		Z	0xC0:08:00:00
		E	0x80:09:00:00
Testing X connection... OK
Testing Y connection... OK
Testing Z connection... OK
Testing E connection... OK
If that came out okay (i.e. nothing says ALL LOW or otherwise implies that there's some fault), check that your motors work, and run in the right directions.
If so, you may now begin routine calibrating and printing.
Enjoy your 32-bit goodness! :-)
As an aside: when you get a chance, you should also adjust the driver modules' potentiometers to set fallback currents, just in case the UART feature craps out some time (e.g. if a connector gets pulled out).
Step 9: Credits and Notes
  • This Instructable was inspired by "UART This!" by seansadler.
  • jammi clued me in to the UART-on-MS3 method via his RAMPS-oriented imgur guide, sure beats unsoldering and/or flipping pins around!
  • The drawing of the pinouts of the SKR v1.1 came from BigTreeTech's public Github repository, modified by me.
  • The photo of the TMC2208 module with the three-pad jumper that's next to the diagnostic holes was made by bookzurman, modified by me, and is used with permission.
  • The photo of the TMC2208 module with three-pad PDN/UART jumper in the middle was "borrowed" from an Aliexpress listing, enhanced and modified by me.
  • The photo of the TMC2208 module with everything on the top side of the PCB was "borrowed" from a Github thread, enhanced and modified by me.
  • The clip of a driver module slot on the SKR v1.4 came from BigTreeTech's manual for that board.
  • All other photos used in this Instructable are entirely my own work.
Fair Use rationale:
Try as I might, I could not find clean, freely-licensed images of two of the driver module variants (the "borrowed" ones above). Only non-free, low quality sources were to be found. Per the "four fair use factors" set forth in US copyright law:
1. Both images are used in a non-commercial, non-profit manner, purely for educational purposes (though I have no control over what Autodesk does with them outside of this Instructable).
2. The original images were published and deliberately made accessible to anyone on the Internet, without any kind of account, password, or other obvious means of access control.
3. The images as obtained from the sources above were low-quality. They have been cropped to just the modules themselves, and then scaled, enhanced, and annotated by me. Due to the nature of the technology, using anything less than the full module images currently shown in this Instructable could lead to confusion, defeating the purpose of their use entirely.
4. These images have no obvious possibility to disrupt the market in which they were originally used, and no preference for one brand over any other(s) is intended.
About the connector and wire colors:
Shortly after I got my original SKR v1.1, I had to satisfy my OCD :-) and so I swapped the motor and endstop connectors around so that X is red, Y is green, and Z is blue, to match what you see in most 3d modeling programs, then color-coded my patch wires to match. However, some time after wiring it up, I killed it while probing around on the board (I shorted something out I guess), but since I still have that dead board in my junk box, I just went ahead and used it for most photos, just so that I didn't have to pull my good, working board out of the printer. The white patch wire seen in some photos is just an extra I had lying around.
The working board is shown in the final image since since I needed a "complete, installed" photo for this Instructable, so its wire and connector colors don't match the other photos.
2 People Made This Project!
  • Halloween Contest
    Halloween Contest
  • Microcontroller Contest
  • Back to School: Student Design Challenge
78 Comments
AtwoodC
AtwoodC
Question 2 years ago
I got a Skr v1.3 bundle with the drivers included. everything else checks out except that I have those 2 unused pads. I'm not sure if I should solder them or not as I did recieve them this summer so they might be UART compatible already. Could anyone take a look and let me know?
78371277_486668115536442_2687772516448993280_n.jpg79888052_2412230462374947_1802091990192488448_n.jpg80066947_743964496099971_6076883110383845376_n.jpg
BenCos18
BenCos18
Answer 2 years ago
the Bigtreetech v3.0 drivers don't need to be soldered for uart mode i think.
AtwoodC
AtwoodC
Reply 2 years ago
Thank you very much. For some reason I was finding it difficult to find any information about the skr drivers
BenCos18
BenCos18
Reply 1 year ago
no problem
Did they work in uart correctly for you btw (Little late replying for sure haha)
motorindexhun
motorindexhun
Reply 1 year ago
It need for me. The pins are not connected to the chip.
BenCos18
BenCos18
Reply 1 year ago
ah ok
I didn't know that thanks for the info(I must have had a different version of the drivers then)
fabian.benedikt
fabian.benedikt
Question 1 year ago on Step 9
Dear Community,
i have Problems with setting up my own build 3d printer.
details:
skr 1.4 turbo, tft3.5 v3.0 display, tmc2208 drivers and mechanical endstops, 100k thermistors (very usual)
My Problem:
if i press "home" (for home all axes) at the display, nothing happens
if i press "home z" the z-axe motors do turn and can be stopped by pressing the z-endstop
if i press "home y" the z-axe motors (no writing error, z!) do turn and cant be stopped
same for x
confusing is also that //#define INDIVIDUAL_AXIS_HOMING_MENU doesnt make a difference whether it is defined or undefined (at the moment undefined, but i do have individual home menu at the display)
Solved Problems from before:
I am using 17HS5425L20P1-X2 stepper motors and already found out that there was a mistake in the wiring of the cables here (it was the order blue green red black first), but corresponding to the data sheets of the motor the black and green wire is for phase A, so i rearranged the cables to the order blue, red, green, black -> my first Problem of a unclear movement of z (z was moving for and back sometimes for allways giving z plus) and x and y were not moving at all (only grumbling at the point of control)
My second solved problem was the mechanical endstop (https://www.roboter-bausatz.de/p/mechanischer-endschalter-mit-50-cm-kabelsatz-3-pin-fuer-cnc-reprap-3d-drucker is in use) i found out that my switch was soldered other way around (lever going from right to left instead) and for that reason i swapped the red and green cable position on the skr board -> result was a "open" and "triggered" state by using M119 over the tft35 display
if i would not swap the connector around it would allways make an complete reset of the skr board if i press the endstop
is this solution acceptable? since the layout of the mechanical endstop is not omnidirectional (i think so)
I attached my files from marlin
Best Wishes and thx for the help
Techno
XavierASX
XavierASX
1 year ago
Hi, and happy new year!!
First of all, great tutorial, Vanessa!
I'm building an HEVO printer and am planning to use a SKR V1.3 board and TMC2208 drivers.
My drivers are like the second black board driver on your tutorial, but I got a little confused about where to do the soldering.
The image shows the continuity measurements I got fro the drivers.
Based on that measures I should make the soldering bridge on the yellow mark or the orange one?
Sorry if it sounds like a silly question, but it looks like soldering on the yellow mark will not create the connection from the driver to the UART interface on the SKR V1.3 board.
Vanessa_E
Vanessa_E
Reply 1 year ago
In the Instructable I indicated that some drivers have a 3-pad jumper with a 0-ohm link on one side. I believe your driver module is one of these.
BUT, since you're using an SKR 1.3, you have all the UART wiring in place in the motherboard already, so you shouldn't need to solder anything at all. Just put a shunt on the SKR's UART jumper pins for the driver slots that use your pictured module.
(if you want to also be able to use that driver module on some other motherboard that's not UART-friendly, you would solder the pads you marked in yellow)
XavierASX
XavierASX
Reply 1 year ago
Hi, thank you for your prompt answer. After I mounted everything, I got a bad response on M122 Marlin g-code. So I measured again and found out that the upper point on the yellow circle (on the image on my last message) was connected to the UART pin on the 2208 chip. Then I soldered that pin to the 4th pin from the top, as shown on the image below, and got successful connection! Once again thank you for your instructables and for being so straigthforward on your communication.
Alerezam
Alerezam
1 year ago
Hi
I want to initialize tmc2208 with micro-controller (in this case STM32) without any extra eval boards or anything else
In Datasheet, there are 2 ways to communicate with tmc2208
1) uart with resistor between RX and TX Pin
2) Bit-Banging
I tried above works correctly but tmc2208 did not response! Even its PDN-UART pin never goes as a master to pull up the line (Playing the role of TX Pin)
I searched a lot but didn't understand why we need evaluation boards?!
or what i didn't consider that I couldn't receive any response?!
Thanks for any response
motorindexhun
motorindexhun
1 year ago
Hello,
I modificated my BTT TMC2208 V3.0 and soldered the MS3 and the middle pad on the chip side. I've measured the connection between the:
MS3 - RST -> not connected
RST - middle pad -> not connected
MS3 - middle pad -> Connected it means I've checked the connections between the MS3 - IC pin 14 (PDN) and it connected now.
I've tried to close the RST+MS3 pins after soldering, because the TMC Connection error was still on the screen. It was useless.
All two 2208 is double checked with MM and with microscope too.
I use the up to date Marlin (2.0.7.2).
The mainboard it a BTT SKR V1.4 Turbo + BTT2208 V3.0(X,Y) + A4988(Z,E0) + E1 empty.
Is anybody have any idea?
stardeep2000
stardeep2000
I got the SKR 1.3 / Big Tree Tech TMC 2208 "kit" and can't seem to get the Board / Drivers / Marlin to all talk to each other in Uart mode. I removed the jumpers on the board other than uart jumper, but haven't soldered anything yet on the driver. I did try jumping the pins to no effect. Can't wait for the i3 MK3 to show up and so I can tinker and print at the same time.
95139929_3201565219875916_699907131821785088_n.jpg95105278_700932920650891_7234230939566473216_n.jpg
stardeep2000
stardeep2000
Answer 2 years ago
I did figure it out, the drivers will not communcate on uart if the board is powered by USB (in my case) I had to have it 1) powered by an outside power source 2) have it switched to use the outside power supply be used to generate the 5v rail.
nathan.a.hodge
nathan.a.hodge
2 years ago
How do you install the TMC2208 library in VSCODE?
Oneofmany78
Oneofmany78
Let me start by saying my deep dive into this has been strenuous to say the least. This board/software side of this is not my strong point. I have a skr 1.1 & 5 2208's. I was trudging along with your instructions until the end. I have a btt tft24 1.1 I had planned on using in tft mode. Has anyone determined pins that will work for this hack. I have 2 z steppers so I can't use e01. Since I don't really understand why the original pins chose were used, I can't even begin to determine which other pins may be acceptable. Any help would be greatly appreciated.
JoshS183
JoshS183
2 years ago
So do I need the resistor in on the wire. I see your wire has a shrink tube in the middle of it. Is that the resistor
Vanessa_E
Vanessa_E
Reply 2 years ago
No, no resistors. This is single-wire UART mode. That heat shrink tube is just covering a plain old splice, since I reused the wires/Dupont connectors from other random bits of electronics. I'm frugal like that. :-)
bookzurman
bookzurman
Question 3 years ago
Vanessa, thanks for a great post, your article is fantastic. I'm struggling to get my TMC2208 to work in UART mode, but I'm not sure what pads need to be soldered together. Can you help me from the pictures? Currently, I get the "ALL LOW" message for all 4 axis' when I issue an M122. Any help would be greatly appreciated!!
Vanessa_E
Vanessa_E
Reply 3 years ago
I'm afraid those modules aren't UART-capable without some extra hacking - you'll have to solder-in a wire to bridge the chip's UART line to the middle two pins on the yellow header. Problem there is I don't know which pin on the 2208 chip is the right one, plus it'll need some detailed soldering, moreso than just closing a jumper (i.e. the one that should have been near those middle pins).
