The Spring Bag
1,301
14
Introduction: The Spring Bag
It is an interactive bag design. And here is the material list:
green silk,
snap button,
copper thread,
LED (green, white, yellow)
wood,
zipper,
fabric glue
Step 1: Cut the Wood Pieces
Use the laser cut machine to cut two wood sheets into pieces.
Step 2: Attach the Wood Pieces to the Fabric
I used fabric glue to make it stable, you can use double sides adhesive tape instead.
Step 3: Add Another Layer of Fabric and Sew Them Together
Make sure that you stretch the fabric before you sew them together.
Step 4: Sew the Snap Buttons and Straps
The holes on wood sheets are cutted for snap button and straps.
Step 5: Finish the Circuit
On one side of the bag, build the circuit as the picture shows. Make sure that you put the LED on the edge of the wood pieces. I used conductive fabric tape to finish the circuit.
Step 6: Sew the Zipper and Build Another Circuit
This part is a little complicated. You need to build the circuit next to the zipper. On one side of the bag, it is a parallel circuit with 3 white LEDs. On another side, sew 2 yellow LEDs and make the circuit as it shows. So that when you zip up and zip down, you can turn on and turn off different LEDs.
Step 7: Test the Circuit
You may want to test the circuit and make sure it works before you sew the two pieces of the bag together.
Step 8: Sew the Two Pieces of the Fabric Together
Step 9: Now You Get a New Bag!
Be the First to Share
    • CNC and 3D Printing Contest
    • Lamps Challenge
      Lamps Challenge
    • Puzzles Challenge
      Puzzles Challenge
    attosa
    attosa
    3 years ago
    Impressive bag!
