Introduction: Tiny Wooden House on a Rock
Hi All,
In this instructables I am going to share how to make miniature wooden house. It is tiny and super fun to make. needs a patients and time.... Main items used in this instructables was found easily. I did not buy anything....
I worked on this project every night after dinner for 2 to 3 hrs ( last 1 week ).. I certainly learnt a lot
Step 1: What Do You Need ?
Material
- A rock or stone : I found mine on road
- Popsicle sticks : Mine were thinner than regular fund them at the coffee station
- PVA glue or fevicol
- Cutter
- Tooth picks
- Skewers
- Acrylic paints etc
- Dried bamboo twigs from my apartment garden
No power tools needed, just you imagination
Step 2: Prepare
- Wash the rock, bamboo twigs and let them to dry
- Glue several popsicle stick to make few thin wooden planks / sheets
- Let the glue dry before we start the next step
- Add supports as needed
Step 3: House
- Cut the wood sheets as shown above
- Glue them together
- I used paper tape to hold them together and added a support inside to prevent it collapsing
- Let it dry for 2 hours
- Add details like doors, chimney and base etc
Tips :
- You could choose a different shape for your house
- To simplify this step, you could take a big piece of wood and shape it into a house using saw and then sticking popsicle picks for details
Step 4: Path on the Rock
- The idea is that this rock is a hill or a island in water
- We have a wooden path which goes around the rock
- This path has is has moss etc
- I started at the top and slowly added each piece
- Added support where the popsicle stick was touching the rock
- After every piece, you need to wait for 2hrs to dry
- Once done paint the patch with watery green and brown
Tips :
- If you are comfortable using super glue, this step gets done faster
- I always end up gluing myself and making change later is difficult
- While one piece was drying I would work on another, like painting or tree etc
Step 5: Boat
- Take 4 to 5 pieces of popsicle sticks between 3 to 4 cm
- Glue them together and leave them to dry
- Once dried, use a sandpaper and cutter to give this a boat like shape
- Leave the boa's bottom flat, so that it could stand upright without an additional support
- Add the central mast and two sails
- Glue them and let it to dry
Step 6: Paint Job
- Using Acrylic paints ( I you may choose different colors)
- Paint brown ( water wash ) to give the wooden finish
- Paint green, let it dry
- Now paint teal Blue, leaving some of the green to still be visible like moss
- You could try different color scheme
- While my looked amazing with a white background, on a darker shelve I will have to change the colors
Step 7: Detailing
- Before we start detailing, we need to glue the house and level it
- I added dummy supports for the house at the back and front
- Added tress ( bamboo twigs)
- Added few more branches by gluing more twigs
Tips :
- Using Super glue could definitely speed up the process
- Take a pause after every step... rest a bit and then continue
Once everything is dried, place the new tiny wooden house to display on the showcase or find a spot
Future Improvements
- Add led lights, why ? Because I love them and will be more visible on a darker shelf
- Add more details to Tree, fence to path and a swing
Please share your suggestion, comments and how can I improve further
