Introduction: To Display Time and Date Using DS1307RTC
In this project in the virtual terminal time and date will be displayed using DS1307RTC.
DS1307RTC:
The DS1307 is a low power Full Binary (BCD) Real Time Clock (RTC) IC with 56 bytes of SVRAM that communicates through I2C Protocol. The IC can work from directly supply on Vcc and switch to Battery automatically when required.
This project is done in Proteus Software using Arduino software.
Through simulation from the Proteus we are making the circuit to work.
The added advantage of using Proteus is we no need to have hardware components, if we have a laptop Proteus software and Arduino software we can make this project.
components required for making this project are
Arduino Uno
crystal
Resistors
Virtual Terminal
DS1307
Step 1: Connect the Circuit
click on this link for DS1307 library
Include the above library in Proteus
Now,
1. Open the Proteus click on new file.
2. Then go to component mode and select the required components.
3. From virtual instrument mode select Virtual terminal and from terminal mode select power and ground.
4. Then connect the circuit as shown in figure.
Step 2: Write the Program in Arduino
click here for Arduino Program
we have to upload some libraries in Arduino:
click on the below links to include libraries in Arduino
https://github.com/PaulStoffregen/DS1307RTC
https://github.com/amorellgarcia/arduino-timer-lib
https://github.com/PaulStoffregen/Time
After writing the program save the Arduino file in .hex extension
For saving into .hex extension click ctrl+shift+s.
Then the Arduino code will be saved in .hex extension.
Step 3: Then Upload Arduino Code Into Arduino Uno and Run the Proteus
Then upload the Arduino code into Arduino Uno in Proteus and then run the Proteus.
Then the output will be displayed as shown.
We have done it !......
