Introduction: Transformable Extended Workbench Part 4
7.3. Belt Grinding Machine
material:
Metal plate 435 x 325 mm
2 wing nut M6
This machine already has inserted two metal bushings, threaded M6.
The plate is drilled 2 holes Ø 7 mm.
The machine is fixed from below to the two wing screws
material:
2 wing nut M6
Step 1: 7.4.grinder
7.4.grinder
material:
Metal plate 435 x 275 mm
Al plate 135 x 120 mm
Square profile 20 x 30 mm
Lower part of pedestal drilling machine
1 x wedge
2 x screws M8 x 40
2 x wing nuts M8
4 x screws M4 x 40
4 x M4 nuts
4 x washers for M4
6 x screws M6 x 40
6 x M6 nuts
6 x washers for M6
Stand angle grinder and stand drilling machine is placed on a metal plate .
Properly arranged -squareness , parallelism .
Marked and drilled 4 + 2 holes Ø 7 - to stand and base .
Fastened with screws M6
Elbow angle grinder
The Al plate make a groove for the grinding plate .
Drill hole Ø 4 x 6 mm screws
The same is done in the carrier profile of 20 x 30 mm .
Al- mounted plate.
Remove the pedestal drill with vise .
Place the bracket to the desired position .
Mark the positions for the holes Ø 7 mm .
2 drilled holes Ø 7
Mounted console with screws and wing nuts .
Note:
Angle Grinder has the option of cutting and grinding .
For the purpose of cutting wedge in the fact that we take advantage of the whole surface of the plate.
When clamping chuck with the original stand the grinder head resting on the workpiece . Can be cut thinner workpieces .
Grinding can use all the plates that match this type of grinder .
Restraint , in order to facilitate work .
Lower metal disc sander has 4 mounting holes . I myself have repeatedly changed positions grinder on the table . The panel provides good stability tool without attachment . For the attachment point on the table , I recommend that you first use it. Then anticipate at least 3 fixing points on the table .
material:
1 x wedge
2 x screws M8 x 40
2 x wing nuts M8
4 x screws M4 x 40
4 x M4 nuts
4 x washers for M4
6 x screws M6 x 40
6 x M6 nuts
6 x washers for M6
Elbow angle grinder
Al- mounted plate.
2 drilled holes Ø 7
Note:
Step 2: 7.5. Lathe
7.5. lathe
material:
4 x screw M6 x 60
4 x wing nuts M6
In a managerial profile lathes and profile tables drill hole 4 x Ø 8 mm.
Fasten it with 4 x M6 screws and wing nuts M6. The holes are larger in order to facilitate assembly and disassembly.
Lathe has accessories for milling, grinding, polishing and sanding drill.
material:
4 x screw M6 x 60
4 x wing nuts M6
Step 3:
7.6.jigsaw
Material.
4 x screws M5 x 30 mm
4 x nuts M5
4 x washers for M5
To conclude, workbenches we have to be shortened Al plate.
This is used to attach the jigsaw
In the palm saws drill hole 4 x Ø 6 mm
Place on the Al plate and mark the holes
4 drilled holes Ø 6 mm
Attach the saw on Al plate
Examine parallelism, squareness
Mark the hole saw blade and produce.
Fixing is by screws 2 x M6 x 40 and two grub screws
Note:
Al plate with a saw blade attached only by two screws because it is fixed until the middle of the cover plate Al plate. Resting is still the leading profile lathes.
Material.
4 x nuts M5
4 x washers for M5
Note:
