Introduction: Two-in-One Kidz Stuff Disinfector
Hi, I'm Tannishtha. I designed this utility called Two-in-one Kidz stuff disinfector. I am going to show you the steps to make it.
Step 1: Step 1: Your Base
Step 1: Drag a box on your workplane. The dimensions should be:
Height- 52.00 Width- 93.00 Length-184.00
Step 2: Step 2: Make Your Compartment Area
Step 2:
Now, cut a suitable hole that laves space at the bottom, and the sides.
Step 3: Step 3: Part the Compartment
Step 3:
Now make another box that divides the compartment in half. I have the dimensions below if you need it.
Height- 45.00
Width- 86.00
Length- 8.00
Step 4: Step 4: the Doors
Step 4:
Now, you need to make doors. Drag 2 boxes onto the workplane. Now put the dimensions differently according to the seperation. Just do 1 of it, group it, and then duplicate it. Also, to make the hinges, use a torus. And after you make the boxes, group them, duplicate, and turn into a hole. then group it to put the hole in, and then place your door. If you want, check out the photo to see what it should look like after.
Step 5: Step 5: the Book/UV Chamber
Step 5:
Now we start working on the Book Chamber. First, you add the rods where the books will be placed. There is a readymade rod which reads "chopstick" Take that and and keep it sideways on the book chamber. Do the same for, like, 2 more. Then you have your book rack!!! Now, take a cylinder and duplicate it. Then, turn the duplicate into a hole and make it smaller. Then you can group it, then angle it, and then take another cylinder, cut it in half so that it doesn't look like 2 smaller cylinders. Now turn the half into a hole and group it in the pipe cutting it in half so that it doesn't look like 2 more pipes. It should look like a pipe cut vertically. Duplicate the new shape 4 times and then turn 2 of them upside down. Now, take a fan and put it at the bottom. Your book chamber is done!!!
See my photo to see what it should look like after.
Step 6: Step 6: the Toy Chamber
Step 6:
Now, the toy chamber. You drag a metal can into the chamber. Then you make the door in the front in the can. Make sure that the can is suitably sized. Put a motor on the bottom. Now put some cylinders that serve as racks for the bigger toys.Then a tiny box for a rack for the smaller toys. Now take a SoftBox and put it on the side of the Toy chamber door for detergent. Use a pipe to connect it to the metal can. See what it should look like.
Step 7: Step 7: Final Touches
Step 7:
Now we are down to the final touches!!! Go to back view, and behind the toy chamber add 3 pipes color-coded for the water input, output, and air-dry. Then add a violet pipe behind the book chamber. Then put 1 slideswitch beside each of the chambers. Then put a clear box on top of the design as a lid. Then drag another workplane against the doors and label them. And... you have you're Two-in-one Kidz Stuff Disinfector!!! Enjoy!!!
