Introduction: Tyvek Bivy Sack for Camping/Hiking
A Bivy, or Bivouac Sack is a bag for your sleeping bag. In good weather, they keep your sleeping bag clean, in bad weather, they keep you dry (mostly)... Bivys are basically a waterproof shell that protects your sleeping bag. They have an added benefit of keeping dew off your sleeping bag, and slightly increasing your warmth. The only down-side is that the bag will trap moisture (perspiration) in the bag. In hot/humid conditions, this can be a big problem.
In this Instructable, I'll show you how to make a cheap bivy that works well in decent weather and is not terribly heavy. In rainy conditions, you should have additional shelter over you. (Commercial Bivys start around $80.)
This bivy is constructed from 14'-15' of 3' wide Tyvek House Wrap, and double-sided carpet tape. The basic design is a full length of tyvek folded at the foot and sealed on the sides.
One important note: This bivy does not breathe. Never seal up an unvented bivy over your head!
Step 1: Materials/Tools
Required Materials:
Approximately 15' of 3 foot-wide Dupont Tyvek Home Wrap (or similar).
Double-Sided Carpet Tape (the permanent kind)
Velcro
Tyvek Tape (optional)
Tools:
Scissors
Measuring Tape
Wallpaper seam roller (Optional)
washing machine
Build Time: Approximately 2 hours, with a break for drying the tyvek...
Step 2: Step 1: Measure and Cut
Lay out your tyvek, Printing side down. Roll out enough to cover the length of your sleeping bag plus a foot or two.
Fold the end, and roll out the top sheet, stopping short of the full length.
You want the bottom to be longer than the top so your head pokes out the top, but under your head is protected by the bivy.
Step 3: Tape Away!
Time to seal those edges.
Before you do, make a note of which side the sleeping bag's zipper is on. This is important, as we won't be fully sealing the bivy.
With the sleeping bag facing DOWN, the side without the zipper will be fully sealed. Start on that side.
Mark the location of the top sheet on the bottom, so you'll know where to stop taping. Plan on leaving about 1inch untaped.
Carefully tuck the tape into the corner, and run the tape up to the mark. Be careful as this tape is sticky stuff. It's not a bad idea to leave a very small gap between the tape and the edge to avoid getting the tape on your work surface.
Step 4: Seal the Seam
Starting at the corner, working in 6" increments, remove the backing from the tape, and carefully attach the top sheet.
Continue working until the seam is complete.
Be sure to press firmly on the seam to ensure good adhesion. I used a wallpaper seam roller (optional).
Step 5: Fold the Corner
stick a small square of tape in the corner. Fold the corner over. This will improve both the look of the finished bag, as well as ensure a good corner seal.
Step 6: Seam the Opposite Side
When we invert the bag, the unsealed side will line up with the zipper on your sleeping bag.
For this side, we're only going to seal about 1/2 the seam.
Using a sharpie, mark the end-point, and tape as in step 4.
Peel and stick the top sheet, and fold the corner as in steps 4 and 5.
Step 7: Crumple Time
If you haven't noticed, the Tyvek is stiff and really really loud. A quick run in the washing machine will fix that... But first, we need to crumple it to make it easier to handle.
First, reach into the bag and pull the foot through the top, inverting the bag. This leaves a nice looking seam, and the printing on the inside of the bag.
Next crumple the bag as much as you can and stretch it out. Do this a few times. This wrinkling makes the tyvek much more pliable, and easier to get in the washing machine..
<EDIT> December 2015: It has been suggested (below) to pre-crumple your material before making... That way you don't end up with a 200lb bag of water in your washing machine... The advantage of post-crumpling is easy assembly with nice flat tyvek, but it would be easier to crumple the material first... I'll let you decide...
Step 8: Into the Washer
Fill a top-loading machine with cold water. DO NOT ADD DETERGENT! Detergents have been reported to break down the tyvek, and they're not necessary.
Push the bag into the washing machine, and start on a regular cycle.
At first, the tyvek won't move much, and you may have to push it into the machine.
As the machine works, the material will be more pliable. When the wash cycle is nearly complete, the material should be moving freely in the water. If it is not, stop the machine and remove the tyvek. You may find that only some of it has been softened. Re-load the tyvek, re-set the timer, and let it continue.
Important note: DO NOT LET THE MACHINE SPIN! (Mine crawled about 2 feet before I could stop it!) The tyvek bag will hold water, and the spin cycle could tear the bag or cause damage to your machine.
When the tyvek moves freely in the washer (see the last picture), it is ready (Mine ran for about 10 minutes). Remove the tyvek from the still full machine. You'll need to remove the bag foot first so it will drain. Be prepared to get wet, as the tyvek will not get wet, and all the water on it will drip off. This water should be perfectly clean, so feel free to re-use it for washing your clothes...
Take it outside, shake it out and let it dry. (be prepared to get wet!) Once the outside is dry, you'll need to invert it again, to dry the inside. Once dry, invert it again, and take it to your work area.
Step 9: Velcro
At this point, your bivy is almost complete. Add a few velcro spots, and it can be opened or closed easily. If you're looking for better warmth and weather resistance, you can add a full velcro strip, or use Tyvek Tape to attach a full zipper.
Step 10: Complete!
You have successfully completed the basic bivy.
Feel free to trim the top edge, (rounded looks nice). but either way, it's ready to use. It folds up nicely, and fits my adult mummy bag well.
Author's Notes:
The carpet tape and tyvek brand tapes are amazing stuff. (A whitewater raft manufacturer recommends the Tyvek tape for field repairs.) The glues on both of these are strong enough to separate the lat\yers of Tyvek, and some thrifty folks use tyvek and this tape to make Boat sails. The seams are difficult to pull apart with the carpet tape, but if you pull the exposed edges apart, the tyvek will fail before the tape will.
The bivy is surprisingly warm by itself, and in a rainstorm a clothed person could crawl in for an emergency shelter. Maybe a comfortable bag liner would be all you'd need in summertime...
Ideas for improvements:
You can seal the full lenght of the bag, and cut the opening down the middle. With a smaller strip of Tyvek, you can add a flap that would overlap (seam with tape on one side and the bottom. Using velcro as a closure, this might work to be more weather resistant.
Most bivys have a drawstring, so you can pull the bviy around your head. Sewing tyvek is hit and miss, as the punctures act like perforations, and are easily torn out. Perhaps a pocket for the head would work better...
For Mummy bags, you can taper the foot area to use less material, and save some weight. As constructed: 10.8 oz, 108g. Total cost. about $25. (with lots of tape left over).
I left the top flap longer than I need. In the event of rain, I can pull it over my head, and avoid getting too wet. With some ingenuity, and some mosquito netting, a complete foul-weather bivy could be constructed.
Tyvek is relatively cheap, and the possibilities are endless! I'd love to see design improvements!
Thanks to my 10 year old model: Sarah for her Bivy demonstration...
1 Person Made This Project!
- tolkientrekker made it!
15 Comments
2 years ago
I know this an old thread, but Tyvek in not directional (no inside our outside). The breathability is due to the micro pores that allow water vapor molecules through, but not the larger water droplets. Same as gore-tex.
Reply 2 years ago
9 years, lol. And yes, I think we came to that conclusion in the thread below. I'll review and update the original. Thanks!!
11 years ago on Introduction
According to the dupont website, tyvek is water repellent (when the tyvek wording is facing out) and allows moisure/water vapor to pass to the outside from the inside. In other words, it "breathes", not las well as cotton would, but is more permeable than cling wrap or plastic. So putting this together with the words facing inside defeats the purpose.
Also, I think it is infinitely easier to cut out your pieces, wring the tyvek instead of crumpling it, then unwring, crumble into a ball and then wash. My front loading machine had no problem with this, as you do not have a "bag" yet and the water spins away.
Then you proceed as usual. I used duct tape and did not bother turning inside out to have neater seams. I am a long time fabric seamstress and it is standard practice to preshrink/pretreat your fabric before assembly. and it worked great here too.
Just hoping to add a few refinements to this great tutorial.
That's a myth. I've used dupont tyvek for mycological work and never oriented the material with any particular side facing any particular direction. If it were true that the material is gas permeable in only one direction, half of my innoculation would have failed.
Reply 7 years ago
Agreed; Tyvek is waterproof and gas-permeable, there is no magic to make the textile waterproof on one side only. The printed side faces outward to provide marketing for DuPont.
10 years ago on Introduction
Great article and the Youtube video was excellent information. The logistics of weight and size are most impressive as they would fit in my sea-kayak where conventional tents and sleeping bags won't.
I'm thinking this product would do well in the Pacific Northwest in the form of DIY tarps and ground covers as well. The other thing (I will need to test out) is if this material will work as a hammock reinforced with either webbing or a poly-line of some type.
Thanks for this posting.
Thanks for the feedback! My biggest concern with tyvek in general is it's breathability, especially in high-humidity conditions.
It works great as a ground cover, but will eventually leak through in boggy conditions. Lots of people use them as inexpensive tarps that are much better than the blue plastic ones... (though I switched to a DIY tarp made from 1.1 ripstop and then doused with a DIY silicone waterproofer. (see: http://www.youtube.com/watch?v=-UTZPllgqSc )
BTW: A few have tried hammocks made from tyvek, with dismal results. I make my own camping hammocks (with zippered/integrated bugnets) 1.1 ripstop (30d) nylon works great, and supports my 210# quite comfortably. You won't find 1.1 at your local stores (normally) but you can get it online for as little as $3.25/yd... (diygearsupply.com) If weight isn't a concern, look up tableclothsfactory.com they have fantastic prices, and a 10' - 11' polyester tablecloth makes a great hammock, cheap. Just "whip" the ends and tie a rope to it. Just make sure you use good rope, and don't hang your hammock too tight, as it multiplies the weight on the suspension. A rule of thumb is 30-degrees down off of level is about right... If you're interested in Hammocks, PM me... I could type about them all night...
John
12 years ago on Step 10
I'm not sure but you seem to be using it with the Tyvek printing on the inside.
You should try it with the printing on the outside. Tyvek is made to "breathe" in one direction. It's basically waterproof on the printed side and the back is supposed to allow water molecules to flow through.
Great idea and since I have half a roll sitting outside and am going camping in two days, I now have a project for tomorrow!
Thanks!
Reply 12 years ago on Step 10
Interesting. I was unsure of that, and left the printing inside for aesthetic purposes. I did a couple of google searches and there was some debate, but better to be safe than sorry...
Unless you're collecting your sweat to use a drinking water in a desert-survival situation! :-/
Let me know how it works out for you!
Actually, it seems that I was wrong...
I did some research on Dupont's web site and haven't found any mention of it being able to "breathe" only in one direction. There is also no mention in the technical documentation of needing to install it with a specific side facing outwards.
Hmm, I guess we were simply told this so that the printing would be visible.
I didn't actually try it. I was going camping with someone who had never gone before and he felt more comfortable with us using a tent. But I'll definitely try it.
Thanks again!
13 years ago on Step 10
Great choice of material Seems perfect for this application! Question: Does the Tyvek lose any of its weatherproof ability when it is softened by wrinkling and washing?
Reply 12 years ago on Introduction
I have found that repeated use does allow some leakage, but it's minor at best. The first washing doesn't break down the structure enough for it to leak. Since it won't absorb water, the vast majority of it rolls off anyway. Even if you HAD a leak, it would take some water pressure to actually go through the fabric... So I guess that means don't use it to make waders, or a boat... Unless you use lots of duct tape to seal the seams. :-)
Though tyvek is "breathable" having such a small area tends to collect moisture.
The size I made is really kid-friendly, I'd need another piece put in for it to be roomy enough for me. I fit, but it's a bit confining.
Reply 13 years ago on Step 10
From everything that I've read, unless you wear a hole in it, it stays waterproof... You have to be careful when removing it from the washer, as the bag will hold water! At some point, the tyvek will peel a part before the tape will fail. One thing I've found with this bivy: It's a perfect size for a smaller person, but I'm a bit too big, I don't have the room I need to comfortably roll over (I flop a lot in my sleep). I might just build a larger version, and taper it to fit my mummy bag. I made smaller bivys for my kids, and they work really well. Just for fun, I crawled into the bivy with my Therm-a-rest and a blanket. After a couple of hours, I could feel the moisture building up, but as I understand it, this is not unique to tyvek.
Nice! I've got a small sheet I have used as a ground cloth under a tarp, but never thought of builidng a bivy out of it! Great concept!
13 years ago on Introduction
Thanks. I've heard heat-welding is not great as you lose the benefits of the random fibers and the material weakens. I just bought some weldwood contact adhesive... it's supposed to work pretty well for low-loads... might work. I'll try sewing it sometime, but the double sided tape is just too quick and easy. I have a tyvek tarp, I'm thinking about building a caternary cut tarp out of tyvek... on the main seam, sewing might be a better idea than a wide taped seam. Thanks!
