Introduction: USB PHONE CHARGER FOR SOME LG,MOTOROLA & BLACKBERRY
well first off i needed a phone charger for my phone,
im very sorry that some of the pics are not very clear i took them with my camera phone and in a low lighted area
Step 1: Materials Needed
first what you will need is a
Cell Phone Wall Charger any kind will do (mine was already cut off, see pic below)
USB Cord
electrical tape
Knife
USB Power Source (ie computer usb port or usb charger)
USB Cord
electrical tape
Knife
Step 2: Fabrication
first cut the usb cord and cut back the insulation to expose the wires. there should be a red,black,green and white. what we need to do is cut the green and white back because we wont be needing those two wires but leave the red and black wires exposed
next strip the insulation from the red and black wires
to prepare the cell phone charger, do the same thing that was done to the usb cord only the wires in my cell charger are red and yellow match the red wires together and the yellow and the black together
ok now that the wires are hooked up we need to test to see that it works
so plug your usb cord into a USB Port then plug in the cell charger in to the phone and see if its charging if it is
Step 3: Wraping It Up
once you got the connections correct you can solder the wires and either heat shrink the wires or wrap them with electrical tape
since i didnt have a soldering iron ,solder or heat shrink tubing i just used electrical tape
