Introduction: Unique Photo Frames From Used Items
Many people waste second-hand goods and throw them away without being recycled. On occasion I will try to make a photo frame from used goods. Hope this can be useful.
Step 1: Follow the Steps Below for the Manufacturing Process
Tools and materials used:
1. Gift paper
2. Used cardboard
3. Sticks
4. Glue
5. Scissors
6. Cutter / knife
7. Solation
Step 2: Step 1
Take the cardboard box that has been square-cut. Then make a hole in the center of the box using a square cutter / knife.
Step 3: Step 2
Spread the glue on one side of each corner of the cardboard to make it sticky with the gift paper. After that, use the cutter again to cut out the gift paper in the middle of the cardboard.
Step 4: Step 3
Spread the glue on the sides of the cardboard box and stick the paper that has been cut into pieces to form space in the center of the box. Then cut the edges of the paper triangles to make it look neat in each corner.
Step 5: Step 4
Paper scissors that are on the edge of the frame (adjusted to the frame to make it look neat). Then glue the paper back to cover the cardboard with wrapping paper to make it look beautiful.
Step 6: Step 5
Take a square card of the same size. Bring also gift paper that has been cut to adjust the cardboard. After that, apply glue all over the cardboard section and stick the wrapping paper on the white part. So even the other side of the cardboard.
Step 7: Step 6
Take 4 or 3 sticks then apply glue and stick to the corners of the frame. Take the frame that was made before and attach it to the top of the stick that is spread with glue.
Step 8: Step 7
Cut out the triangular cardboard / according to what you want to form a supporting frame on the back. Use solation to connect it. And photo frames made of cardboard and gift bags are ready to be displayed and saved the photos as you wish
