Introduction: Unnakai - Stuffed Ripe Plantain With Coconut
Unnakai (also called Unnakaya, Kai Ada, Unnakka, and Kai Porichathu) is a spindle shaped sweet dessert made chiefly of plantain. It originated from the Malabar region of India, and is often eaten at weddings other festivities. They are super good with the crunchiness of coconut inside and random bites on the ghee fried cashews and raisins.
My husband and I had been to my in-laws place this weekend. They had prepared Unnakai for us. It was a delight.
I would like to share with you this age old recipe.
Snack Stuffed Banana unnakai is very easy and healthy snack chiefly made of ripe plantain.This is very delicious and sweet dish.
Step 1: Ingredients:
Ingredient:
Ripe banana`s(Nenthra pazham) - 5 nos
Coconut - 1 cup
Sugar - 3 tbsp
Cardamom powder - A pinch
Ghee - 1 tbsp
Oil - As required for frying
Cashew - As required
Step 2: Steam Cook
Steam cook the plantains in a steamer, untill they cook well and turn soft. Peel off the skin and remove the middle seed portion of the plantains and grind them in a grinder without adding any water. Keep it aside. You can also mash them.
Step 3: Filling
Heat the Ghee in a pan and add cashews, raisins and grated Coconut into it. Add sugar into that and mix well till coconut become light brown.
Step 4: Roll
Roll the mashed banana with a rolling pin. Roll it on a greased sheet. Grease your hands with a little oil. Fill coconut mixture in between.
Step 5: Oval
Close and roll in oval long shape. Lock the open sides of the flattened banana mixture and shape them as you see in the picture. Repeat the process with the remaining banana.
Step 6: Deep Fry
Heat oil in a deep frying pan. Fry this stuffed banana (unnakai) at medium heat until it become light brown. Deep fry them in oil and remove it on to a plate lined with tissue paper to drain away excess oil. Serve it with tea/coffee.
Note: If you are concerned about the deep frying, you can even shallow fry.
Cooking for One Challenge
Heirloom Recipes Contest
9 Comments
5 years ago
What type of oil would you suggest?
Reply 5 years ago
I usually use the vegetable oil which doesn't impart any flavor.
Reply 5 years ago
Thank you!
5 years ago
look delicious dear... will try it soon
Reply 5 years ago
Thank you :)
5 years ago
thank you delicious
Reply 5 years ago
Thank you :)
5 years ago
think I'll try a cheese-stuffed version. After trying these of course.
Reply 5 years ago
That's an awesome Idea :)
