Introduction: Using Button to ON & OFF Led With CloudX M633
<img src ="https://www.instructables.com/files/deriv/FLC/57B2..."/>
Did you know that you can use CloudX M633 to turn on an LED when you press a button?
In this project am going to show you how you can use button to ON and OFF Led. when you press the button the led will on, when you press it again the led will off.
Step 1: Component
Get all this component if you want to start;
- CloudX M633
https://www.instructables.com/files/deriv/FP5/TFFN...>
- CloudX SoftCard
- V3 Cable
- Led
- Button Switch
- Jumper Wire
- 10k resistor
- Breadboard
You can get your component Here
Step 2: HARDWARE
follow this circuit
<img src="https://www.instructables.com/files/deriv/FLC/57B2...>
Step 3: CODING
Copy this Code to your CloudX M633
#include <CloudX/M633.h>
#define BULB pin1 #define Button pin2 bit flag; setup(){ //setup here pinMode(1, OUTPUT); pinMode(2, INPUT);
BULB = LOW;
loop(){ //Program here if(Button == 0 && BULB == LOW){ delayMs(250); BULB = HIGH; // turn on digital pin 1 } if(Button == 0 && BULB == HIGH ){ delayMs(250); BULB = LOW; // turn off digital pin 1 } } }
