Introduction: Vintage Luggage/Gift Tags
A simple postage/luggage tag, perfect for adding to Christmas and birthday gifts and cheap to make out of materials from around the home.
Step 1: Materials
These are normal household materials, no need for any silly craft supplies.
You will need:
-Packaging (brown) paper
-Card
-Glue Stick
-Scissors and or Guillotine
-Pencil
-Ruler
-Hole Punch
-Pen
-Teabag
-Cup
-Stamps
-Twine or String
Step 2: Ageing the Card
Vintage style paper is a slight brownish colour. I only have white card but tea will take care of that :)
Half fill a cup with warm water and add a tea bag and allow to soak for around 30-40 seconds (doesn't really matter)
Squeeze the teabag to remove most of the moisture and rube over one side of the card.
-Don't squeeze too hard or else it will burst and you will have bits of tea leaves over the card-
Allow to dry for 5 minutes and if desired apply a second or third coating to darken the card further, allowing drying time inbetween
And voila, 50 years of age in 6 minutes :)
Step 3: Apply Backing
For the reverse of the card I thought it would be more authentic to cover it in brown packing paper.
To do this, glue the reverse side of the card (unstained) and apply a sheet of the brown paper, and allow to dry.
Step 4: Cutting Out the Tags
Next draw the shape you need with your pencil and ruler.
I measured 5cm across and 7.5 and 9cm up so I was able to get 3 tags vertically from my page
At the 7.5cm mark I measured at an angle to the 9cm line to create the tag shape
Once I had drawn one row I cut it out using the guillotine, and an extra two rows but not drawn on, as this is time wasting
After each tag was cut out using the scissors, use one as a template to cut out the rest, and there you have as many tags of the same shape as you want.
Now use a hole punch to make the hole near the top in the middle.
Step 5: Personalise
Now it's time to make it your own.
You can write out the recipient's name in joint writing and a message of your choice.
On the reverse apply a postage stamp. I added a postmark with the aid of 1 and 5pence pieces and drew some wavy lines
Step 6:
Add some string and there you have it a lovely tag to go with any present.
Thanks so much for reading and good luck :)
Feel free to comment with and suggestions or problems
3 Comments
10 years ago on Introduction
Dumb question, why glue brown paper on the back instead of just tea staining the back too?
I made some vintage looking price tags for my booth at the antique store by cutting them out of brown paper grocery bags.
That's not dumb. I was going with an old postal theme and this is what they would have wrapped parcels in.
You could stain both sides if you like, I just thought it went better with my style.
Here in the UK we don't have any paper grocery bags unfortunately, but a very good idea for our friends across the pond.
Thanks for reading and commenting :)
Awesome. I love the addition of the postmark!
