Introduction: Walking Dead Zombie Cake
This is a zombie cake I made based on a zombie/walker from AMC's The Walking Dead. I modeled it after one of Greg Nicotero's walker cameos. It is all cake, covered in fondant and hand painted.
I used 4 box cake mixes, altered using this WASC recipe:
White Almond Sour Cream (WASC) Cake
Dry Ingredients:
1 box mix
1 cup sugar
1 cup flour
1/8 tsp salt
Wet Ingredients:
1 cup sour cream
1 cup water
3 large eggs
1 tbsp flavoring extract
Pre-heat oven to 300.
Thoroughly mix dry ingredients in large bowl. In large mixer bowl combine wet ingredients. Put 1/2 of the dry mixture into the mixer bowl with the wet ingredients and mix on medium until all ingredients in bowl are wet (will still be a little lumpy.) I use the whisk beater on the mixer. Then add in the rest of the dry mix and mix on medium-high until well mixed and no lumps, about 2 minutes, scraping the sides of the bowl once or twice. Pour into prepared pans. I like to brush my pans with a mixture of equal parts shortening, canola oil and flour.
Bake at 300 for 20-30 minutes, depending on the size of the cake, then turn the oven up to 325 and bake for an equal amount of time.
I made two 9"x13" cakes and four 8" round cakes.
I used homemade marshmallow fondant using Elizabeth Marek's recipe, which can be found here:
http://artisancakecompany.com/2012/11/the-best-marshmallow-fondant-recipe-ever/
Step 1: Stacking the Cakes
Once you have all the cakes baked and leveled, it's time to begin stacking.
First, cut both 9"x13" cakes length-wise, the round off the corners of 3 of the pieces. Then stack them on a foil-covered cake board, alternating with icing in between the layers. With the 4th piece that didn't get the corners rounded, cut off about a 3" section and set aside. Next, stack the larger piece on top of the 3 layers that were just stacked.
Next, begin stacking the round layers on top of this, slightly off-center. Stack 3 of the 8" rounds. Take the 4th 8" round and cut it in half and apply it to one side of the stacked cakes as shown, using a small portion taken from the 3" section you cut from the long cake, using icing, to give added support. This side will be the back of the cake.
Now, cut a wooden cake dowel about 1.5" shorter than your stacked cakes and sharpen one end with a pencil sharpener and then smooth the edges using fine grit sandpaper. Next, push the dowel down through the top of the stacked cakes and into the cardboard cake board. This will add extra support and help keep everything together.
Step 2: Carving the Cake
Begin the carving by first rounding off the edges, then slowly continue carving and shaving off cake until you have reached the basic shape. i actually ended up having to add some more cake to the top of the head, as you can see in the photos.
Once the basic shape is done, carve out depressions for the eyes, around the nose and a larger area for the mouth.
Step 3: Applying the Fondant
Once the cake portion is carved into it's basic shape, cover it all in a thin layer of icing. Then roll out a piece of fondant large enough to cover the head. Since this will be a zombie and doesn't need to be smooth, you don't need to cover it all in once piece. I covered the head and neck area in once piece and then added pieces to cover the rest, blending the seams in using water, my fingers and Wilton fondant/gum paste tools.
Next comes all the details. Here is the order I did them in and how:
First, I made an ear (he only gets one) by making an oval of fondant then flattening it. Next I shaped it with my fingers and used the smaller ball tool to create the details of the ear. This was applied using water and a paint brush, then smoothing the front edge of the ear to the side of the head using water with the ball tool and my fingers.
Next came the eyes. First attach 2 balls of fondant with water, then flatten them some. Next make 2 flattened almost half circle shapes a little longer than the flattened eyeballs and these will be the lower eyelids. Apply with water, smoothing the seams with the small ball tool and fingers. Repeat for the upper eyelids. Then I used various tools to make wrinkles and detail. I also added more to the brow, building it up using fondant, again applied with water and smoothed the seams and added detail and texture.
Next I used one of the tools to make indents in the mouth for the teeth, which were formed from little balls of fondant and glued in with water.
Next, I added more fondant to the nose, smoothing and shaping and texturing. Then I continued texturing the face. I would brush on water, then use various tools to scrape, puncture and detail the skin to make it look like zombie skin.
For the front of the shoulder that is seen through the shirt, I made a little piece from fondant, textured it, and glued it on with water. Next cake the clothing, which I rolled out and cut, then textured it by laying a clean towel over the fondant and pressing into the fondant to get a cloth-like texture.
The hair was the hardest part. I applied fondant strips, arranging them as I placed them on, again using water.
Step 4: Painting and Finishing the Cake
I chose to hand paint the cake because I thought it would give a nice texture for a zombie.
I started with light washes of food coloring mixed with vodka, building up my colors. The first layer was an all over light wash of flesh tone, then came a light wash of a mossy green on the hair and in various places around the torn flesh areas. Next I used a little darker mix of a muddy reddish-brown.
Next I painted the inside of the mouth with a dark brown-black. Then I mixed a dark purplish brown for the torn flesh and topped it off with a dark blood color. I then painted the clothing and applied the blood coloring to them, as well as spattering some "blood" over the whole thing.
And now the cake is ready to be devoured! Mmmmmm zombie cake brains!
Grand Prize in the
Halloween Food Contest
48 Comments
5 years ago
I'm making this for my orthopedic surgeon that put me back together. We discuss The Walking Dead before we discuss what's going in with me!!
6 years ago
this is one of the best cakes i have ever made thank you
7 years ago
Hi, amazing cake, I was just wondering what size cup you used and what box mix you used; thank you so much! Wonderful cake
Reply 7 years ago
Hello there! Thank you!
I use the Duncan Hines® Signature box mix and the cup I use is just a regular 1 cup measuring cup.
Thanks again! :)
T. Chitwood
Reply 7 years ago
Thank you very much!
7 years ago on Introduction
OMG so scary cake
8 years ago
That is amazing!
8 years ago
The walking dead is a great show well my favorite show. I'm 12 and love baking and making sweets but there is no way I could ever do that great of a job on a cake
8 years ago on Step 4
I fall . I try making this didn't look right. but the cake was good. lol
8 years ago on Introduction
I am 14 and dream of one day being a baker or pastry chef. You have amazing skills and I dream of one day being as talented as you. You inspire me to learn more and more, so I just wanted to thank you for doing this.
Thank you! :)
this is amazing
Thank you so much! :)
8 years ago
Wow!
this is fantastic
so cool!
Thank you! :)
awesome
Thank you! :)
