Water Powered Calculator (Original)
136,377
251
167
Introduction: Water Powered Calculator (Original)
This Instructable will show you how to make a very simple water powered calculator.
I built this because there was a time that we forget to buy a supply of AAA, AA, C, D and LR44
battery so I built this. It solve my problems so it might do the same for you too. Check out for more projects by: angelo10.
This is the original version by: angelo10
Please give the credits to me not for your selves. I saw people getting my pictures and telling  others that they made it. Please don't get all the credits!
Proud to be Filipino (pinoy) like Manny Pacquiao.
Step 1: Meterials You Will Need
You will need:
- A Calculator
- Carbon Rod/ Copper Rod
- A 1x1 Inch Aluminum Foil
- A Small Cylindrical Container
- Two 3 Inch Wire
- Multi Purpose Pliers
- Glue Gun
Step 2: Making Some Holes
Use a drill or a pointy object to make some holes located on the bottom and lower side.
Step 3: Adding the Carbon Rod (Positive)
Glue the carbon rod  in place as the positive rod. The carbon rod is from a used AA battery.
Warning: Never open alkaline "it is messy".
Step 4: Adding the Foil (Negative)
Glue the foil in place as the negative plate.
Step 5: Connect the Water 's Wires
Connect the wire of the water battery, and glue it so it won't leak. Positive wire connected to carbon rod while negative is connected to the foil / zinc.
Step 6: Disassembling the Calculator
Disassemble the calculator with a screwdriver.
Step 7: Connect the Water Battery to the Calculator
Connect the water battery to the calculator. The carbon rod is positive while the aluminum is negative. Be sure to disconnect the solar panel.
Step 8: Assemble It Again
Put it back together again.
Step 9: Fill the Water Battery
Liquid Rating:
Water - Good
Water With Salt - Better
Vinegar - Best
Step 10: You Are Done
You are done. You just need to refill it a again after it run-out of power. Adding more water batteries would be better.
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    167 Comments
    shalo
    shalo
    11 years ago on Step 3
    aside from batteries where can you find those cooper rods? pls help im so desperate :( and im from the philippines as well so if you a pls tell me:)
    ASCAS
    ASCAS
    Reply 11 years ago on Introduction
    It's hard to find one, probably in construction hardwares, they usually call it copper tubing. I made another design of the water battery by only using copper wire and nails. My new version is more efficient, more powerful and uses mor common materials.
    austinbro217
    austinbro217
    11 years ago on Step 9
    Nice job man! I am just starting to explore electronics at 15 years old, and you are an inspiration for me to keep with it!
    ASCAS
    ASCAS
    Reply 11 years ago on Step 9
    Thanks! But what ever you do, never give up, specially when you fail. Use your failures as your guide and try and try again, later on you will succeed.
    dagob
    dagob
    What an interesting instructable! Thanks for sharing!
    I think you should explaing why it works (scientifically)
    Pranjal Joshi
    Pranjal Joshi
    this is marvelous project...!!
    bt u cn do better with carbon n zinc rod using general acids.. :) wel done
    aschmois
    aschmois
    Great tutorial, my first try I had water leaking from everywhere and only a mere .3-.5 volts. Vinegar is NOT the best solution. I have tried and what seems to work best is Lemon Juice and Salt. (water and salt is still better than vinegar). The picture has two batteries in series which add up to a good 1.5 volts. However, for some reason I cannot get a light to turn on. My guess is that voltage reading stabilizes with a circuit, but the bulb cannot stabilize. Might also be the amperage not being high enough.
    ASCAS
    ASCAS
    Nice job. I recommend you to clean each carbon rod carefully, there's a lot of manganese sticked on it. Second both metals should not touch. Third if none of this work make 2 more of this in parallel
    ASCAS
    ASCAS
    Yeah (:D) try adding a joule thief powering a LED bulb. It should work.
    chaitanyak
    chaitanyak
    12 years ago on Introduction
    most innovative - yet simple thing i found today! Good job!
    Dipankar
    Dipankar
    How long does the battery work? Good Idea. Keep it up.
    mathman47
    mathman47
    Reply 12 years ago on Introduction
    I think we have a good kid here. Now if he'll take after you.
    Dipankar
    Dipankar
    Yeh! He's a bright kid. Hope he does well in life.
    artworker
    artworker
    Innovative. Nicely done! It's sad that teachers don't encourage these projects in school! Every student should know these tricks. 5*
    garciatin
    garciatin
    Question 5 years ago on Step 7
    what white something that you put in the container near in the rod? Can you explain.
    saeidhaghighipour1376
    Can we improve this to generatepower for other devices?for example a TV or a laptop.
    Anirudh Ralhan
    Anirudh Ralhan
    6 years ago
    Absolutely Amazing. You Rock. Made a great use of reverse electrolysis. A big Salute to you.
