Wind Proof Your Trash Bins
Introduction: Wind Proof Your Trash Bins
This solution will keep your bins from falling over in bad weather with ease while keeping a minimal asthetic when not in use.
1/4" spool of bungee cord
15" yard stakes
https://www.amazon.com/dp/B00XVIYHKC/ref=cm_sw_r_cp_apa_fabt1_wlxWFbMA7WAYV
https://www.amazon.com/dp/B077LY5Q9W/ref=cm_sw_r_cp_apa_fabt1_mnxWFb2RX48FQ
Step 1: Pick Site Carefully
Pick a site with no lines or pipes burried
Step 2: Insert Stake
Insert stake using a dowel.
Step 3: Cut Bungee
Cut bungee cord to size allowing propper tension.
Step 4: Add Hooks
Add hooks and tie a simple knot on both ends.
Step 5: Insert Bungee
Insert bungee cord through anchor loops.
Step 6: Try It Out
Roll bin over bungee and fasten with hooks in front so the garbage man can easily unhook them.
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Game Design: Student Design Challenge
    3 Comments
    oragamiunicorn
    oragamiunicorn
    2 years ago
    I've used a similar technique recently, but have found that the bungee has perished to the point of breaking in a few weeks of winter. it could be a one off, but I don't think bungee stands up well for prelonged use outside so would consider using a nylon rope if this were for anything long term
    roywlogan
    roywlogan
    Reply 2 years ago
    I just might. This hasn't been tested for longer than a month yet.
    tmspro
    tmspro
    2 years ago
    Be sure to check with whomever picks up your garbage and recycling before doing this. Where I live, if the bungees are not removed before the truck arrives, they will not be emptied.
