Wine-Stained-Cork Cross Necklace
90,641
38
Introduction: Wine-Stained-Cork Cross Necklace
About: I make it up as I go.
Wine is great.
Wine corks are... meh.
They're one of those things that you save because you think you'll do something with them eventually. But you don't. Don't lie.
Well here's your chance to actually do something!
Good for you!
Step 1: Collect Supplies
What I used:
6 corks
a giant binder clip
xacto knife
toothpicks
11 eye pins (.75in)
felt scraps
scissors
super glue
7 open jump rings (6mm)
pliers
Since my brother's best friend's dad owns a winery, corks are easy to gather. If you don't have this luxury, feel free to down  6 bottles of red wine. No judgement.
I chose corks naturally and deeply stained by the red wine and ones that had an interesting wood grain .
Step 2: Cut the Cork
Use the binder clip to hold the cork as you cut it.
This way it is steady and your fingers are out of the xacto blade's way.
Use a rocking motion with the knife to cut about .25 inches of the end of the cork off.
Repeat this until you have your 6 stained ends.
Step 3: Poke Them Holes
Arrange your corks into the shape of a cross.
Then use tooth picks to  punch holes through the cork, as shown in the picture.
Be sure the hole is not too close to the edge and that your toothpick is going straight down, not slanted.
Step 4: Insert and Bend the Eye Pins
Insert the eye pins into the holes, with the eyes on top.
Bend the ends so they are flat against the bottom.
Step 5: Back It Up!
To seal the back, I used some scraps of felt.
Cut out circles in the size of the cork.
Use super glue to attach.
Step 6: Connect the Corks
With the open jump rings and pliers, thread the rings through the eye pins on the cork.
Though I like the look of the hardware, they will not actually keep the shape of a cross and will flop around.
Simply put a drop of super glue where the each of the cork meets each other. This will hold the cross shape!
Step 7: Wear It!
String a chain through the top ring of your new pendant and boom. Done!
Go you.
Dremel Jewelry Contest
Be the First to Share
    • For the Home Contest
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
