Introduction: Wooden Toy Racecar Out of Recycled Skateboards
Hello everyone!
In this instructables I'll show you how you can make a beautiful wooden racecar out of old recycled skateboards. It's so fun to work with old skateboards, it"s so colorful and you get beautiful results!
Step 1: Preparing the Skateboards
First you need to peel off the griptape. It helps when you heat it up.
Make a rough surface for the glue with the sander.
For these racecars we will use the flattest part of the board: the middle section. So we'll cut off the nose and tail on the bandsaw.
And we will be cutting it into strips of 3cm wide. For one racecar we will need 4 strips. You can glue and clamp them together right now, for 24hours.
Step 2: Shaping the Racecar
Now you need to transfer a pattern of a car you like. You can send me an e-mail at creatiedroom@outlook.com if you want my pattern. You can cut it out on the bandsaw or the scrollsaw.
Now there is a lot of sanding left to do. I did this with the belt sander.
Step 3: The Wheels and the Axles
I drilled two 7mm holes for 6mm wooden dowels (axles).
Make 4 wheels with the holesaw. ø 27mm
You can sand your wheels smooth by putting it in your drill on a bolt. I'm sanding mine up to P240.
Step 4: Assembly
Glue it all together and put some washers in between the wheels and the body.
Cut off the axles on the bandsaw and sand them flush with the wheels.
Now you are ready to race!
If you want to see the full video: https://www.youtube.com/watch?v=LEFcZia8ZfE
Woodworking Contest
1 Person Made This Project!
- Creatiedroom made it!
8 Comments
Question 4 years ago
Very nice project! Another step would be adding wheel bearings. Anyways, where would a non-skater find a few broken skateboards for this type of project?
Answer 4 years ago
Thanks!
Just ask in a skateshop nearby!
4 years ago
What a great upcycle project! Never knew there were so many layers inside a skateboard!
Reply 4 years ago
Thank you very much! Yes it's beautiful to work with!
4 years ago
I love these, very well done!
Reply 4 years ago
Thank you very much!!
4 years ago on Step 4
how cleaver and how attractive the skateboard profile is. I can see this used for many things. Good work. Nice Instructable.
Reply 4 years ago
Thank you very much! Yes, I love working with the skateboards because of the colors! It's so beautiful and attractive!
