Introduction: Worm Cafe - Compost With Earthworms Right in Your Garden
I had seen this idea somewhere else but wanted to make some changes that would work better for my situation. I hope it helps someone else also.
This is installed in my Square Foot Garden bed but would work in other gardens also. For more information about Square Foot Gardening contact me.
Composting is a way to reduce what is thrown away while adding to the health of your garden soil. Although I compost otherwise I was excited about the idea of composting right in the garden. Compost should be ready much sooner this way with less work: no turning compost, and no moving compost to the garden.
If you are not able to have a traditional compost bin this may be a way you could still make compost.
Step 1: Gather Materials
Find or purchase wood.
I found four, 1"x5" pieces of 2' long lumber around my house - three cedar, and one Douglas Fir. Any kind of wood should be fine, but I advise against using pressure treated, painted, or stained lumber. You could use 2 1/2' or 3' long lumber instead of 2'.
You will also need a drill, bits and screws, about 2 cups of peat moss, kitchen scraps, a board or post cap for a cover, and a few earthworms.
Step 2: Prepare the Boards
Drill 1" holes within 6" of the end of each board.
These openings will allow the worms to come and go - eating kitchen scraps in the cafe and then traveling through the garden leaving castings and aerating the soil.
Step 3: Put Your Cafe Together
Fasten the boards together with screws – long sides together. I used 4 screws per side.
Step 4: Choose a Location
Choose a place in your garden to place the "Cafe”. It would be best if there is not landscape fabric or anything else which will prevent the worms from going deeper when the temperature drops or rises.
I chose this empty square in my Square Foot Garden.
Step 5: Dig Out a Hole for the Box
Dig out the soil to a depth of 6” and a little larger than the box is wide.
Step 6: Put the Box in the Hole
Place the box into the hole with the end with the holes facing down
Step 7: Fill the Hole Surrounding the Box
Fill the hole outside the box with soil, making sure to save any earthworms you find so you can add them later.Fill the hole outside the box with soil, making sure to save any earthworms you find so you can add them later. Fill the hole outside the box with soil, making sure to save any earthworms you find so you can add them later.
Step 8: Add Earthworm Bedding
Add about 2 cups of damp coir (coconut fiber), shredded paper, finished compost, or peat moss into the box
Step 9: Add Earthworms and Kitchen Scraps
Put the saved earthworms into the box. If you find a few more earthworms around your yard you can add them also.
Add some kitchen scraps (vegetable or fruit peelings) into the box (about 1 cup). Never add dairy products, meat, fat, or bones.
Step 10: Cover It
Put a board or decorative cover over the top of the box to keep out rain and flies. A post cap could be used for a more decorative look.
Step 11: Alternatives
I also made one out of a cardboard box for another bed in my garden. It may not last long but I thought I would try it anyway.
Step 12: Don't Forget to Feed Your Earthworms
Kitchen scraps can be added on a regular basis. Check and see how fast the earthworms are consuming the scraps to get an idea of how much you can add and how often. You may be able to add a cup or two at least once per week.
This is new for me so I am trying it out for the first time. I would be interested to hear how it is working out for all of you that try it.
Step 13:
Update on my Worm Cafe. I checked it June 9 and it looked like finished compost. In addition to the fruit and vegetable peelings I added on the day I built and installed it I had added a bit more a few days later. So, in two weeks or less it was consumed and composted by the worms! The cardboard one was installed a day or so before the wood one and it didn't do quite so well. There were still recognizable pieces of vegetables. The cardboard also blows away easily.
First Prize in the
Garden Contest
1 Person Made This Project!
- samuel.dominguez.129 made it!
84 Comments
10 months ago on Introduction
We have moles in our yard. I would love to do this but fear the mole(s) would think it an ‘all-you-can-eat’ buffet. I have a medium size garden along with a 4’x8’ raised bed. It only has cardboard in the bottom. I’ve found tunnels leading up into the raised bed.
ideas? Tips? Anybody else with this issue? We may have voles too.
Reply 10 months ago
Hardware cloth (available in rolls from hardware or lumber stores) can be stapled to the bottom of raised beds to prevent creatures from digging in from below. With existing raised beds maybe there is a way you can remove some of the soil mix and attach the hardware cloth at least part way down so you can still easily plant in the top but deter digging from underneath.
Question 1 year ago on Introduction
Hi! I want to build two of these one for each of my new garden beds I ordered. Does it matter what part of the garden bed I put it into ? The beds are 8ftX 2ft. does a corner vs the center make a difference?
12 years ago on Introduction
There is a basic flaw in this: Earthworms are not composting worms! You need red worms for that.
All you are likely to get is a bigger and bigger pile of garbage.
Reply 6 years ago
All earth worms compost.. it is a matter of how long it takes them to do they job. I raise African night crawlers and they will turn a compost bin faster than any other worms. For a very long time people have been convinced that you MUST have red wigglers.. but they do not even do as good of a job as the Africans.
Nope! Night crawlers will compost too.
Reply 11 years ago on Introduction
I've had something similar in my garden for the past few years (a small plastic garbage bucket with holes drilled below the soil line) and my wife and I cannot outpace the earthworms. We use it in the asparagus bed and it works just fine from early spring until hard freeze in the fall.
We throw garbage in. And then we throw garbage in. And then we throw more garbage in ... and that little pail never gets much over half full. I don't think it would get even half full if the earthworms didn't have to wait until the bacteria had a chance to get things broken down somewhat.
This guy posted an instructable of a working system. Ergo: no basic flaw.
Thanks for letting me know of your success!
Reply 12 years ago on Introduction
There are earthworms that live only in composting materials and earthworms that compost kitchen scraps but live in the soil. Since the worms are not living in the compost but using it as a food supply there should not be a problem with using worms from your garden.
6 years ago
how will the worms get air? i made some composters out of 5 gal buckets but i have air holes in the top/ sides? thank you!
7 years ago
cool idea! Adding redworms would probably speed things up. You could also modify and add some poles/wiring for beans or other climbing plants.
7 years ago
here's my inspired copy
7 years ago on Introduction
I live in Oklahoma and I am going to try the café with a few European nightcrawlers
This a great idea!!! I saw a solar light post cap at HD that would be great abound the garden. Definitely going to try this!
9 years ago
Once you put the coconut or peat moss in initially, will you ever have to go back again and do this over? I live in central NC and am planning this but would like to make them more permanent since we have pretty mild winters.
I never added any more coir, peat moss, or newspaper. I only added vegetable and fruit scraps from then on.
8 years ago
Update.
Everyday that i have looked at the compost it goes down a lot! Way more than i would expect from it just condensing due to gravity. When i threw it in, it was pretty wet and well pulvarized. the first pic is the night i built it, and then i took one every morning since
It should be going down since the worms are consuming it and then spreading their castings through out your garden and there are microbes breaking it down also. I have never put that much in at once so it is interesting to see how it is working for you.
9 years ago on Introduction
So I made it. It was so easy and went together so fast. I used a flat rock for my top. Once again, Thanx!!!
OMG! What a wonderful idea. I am going out and making myself one in the coming week and maybe one for a Christmas gift. Thanks for the great 'ible!
And to Kelser (and anyone else with an ant problem) try cinnamon. Sprinkle it around and that should repel your ants.
