Introduction: Woven Bracelet With Pearls and Silver Wires- a Particular Gift for Your Best Friend
In this tutorial, I will tell you how to make a woven bracelet. You will be amazed that some beads and wires can make a beautiful bracelet.
Step 1: Material and Tools Needed in the Woven Bracelet:
10MM White Pearl Beads
8MM White Pearl Beads
Glass Rhinestone Beads
1.5MM Silver Aluminum Wires
0.3MM Silver Copper Wires
DIY Jewelry Tool Sets
Bent Nose Plier
Step 2: Bend a Main Shape of the Woven Bracelet
1st, prepare a piece of about 380mm silver aluminum wire, and bend it like the shape in the first picture;
2nd, bend the end of the wire and ensure it can fasten to the other side;
3rd, use some silver copper wires to fix the both sides as the picture shows.
Step 3: Add a Middle Part to This Woven Bracelet
1st, prepare a piece of about 280mm silver aluminum wire, and bend it to the shape as the second picture shows;
2nd, use some silver copper wires to fix the 4 ends to the middle of finished silver aluminum loop.
Step 4: Fix the Shape and Decorate the Middle Part
1st, prepare 2 pieces of about 160mm silver aluminum wires, and bend them to the shape in the first picture;
2nd, attach these two bended silver aluminum wires to the finished silver aluminum loop;
3rd, embed a 10mm white pearl bead on the middle of the bracelet with silver cooper wires;
4th, string a 8mm white pearl bead and a glass rhinestone bead on a silver cooper wire, and fix it to the bracelet like the picture.
Step 5: Attach Some Pearls Beads and Glass Beads to the Bracelet
1st, fix a same one to the other side, and look at the middle of your bracelet, fix another 4 pieces of 8mm pearl beads and 2 glass rhinestone beads to the correct position as the picture shows;
2nd, then that’s the final step, turn your bracelet and fix a 8mm pearl bead to the small loop in both sides.
Step 6: That's the Final Look of the Woven Bracelet:
Just with simple beads and wires, you can make such a beautiful bracelet. Do you want to have a try? Try to make one for your best friends, I'm sure she will like it.
14 Comments
4 years ago
Best of a fantasy product
5 years ago
its so pretty...keep up the good work.
5 years ago
Like this bracelet . It's different .
Reply 5 years ago
Hi, thanks for your affirmation. Have a nice weekend!
5 years ago
5 years ago
funny, excellent !
Reply 5 years ago
Thank you. Nice day~
Reply 5 years ago
5 years ago
I am in LOVE with your work! I was trying to twist my wire around and finally gave up ...frustrated...till this tutorial popped up.
thanks ...I will be trying this very soon.
Reply 5 years ago
hi
Reply 5 years ago
Thanks for your support. Have a nice day!
5 years ago
i really love your flowers this is from lexus green
5 years ago
eh is there a good way to fix pearls or structures? My wire ends sometimes stands out and tends to make sharp edges.
thanks
Reply 5 years ago
Hi, you can flatten the wire to avoid to hurt. Try to slide the pearl on the wire and twist them together~
