Introduction: Zassenhaus Coffee Grinder Mod
Zassenhaus coffee grinders have been well-liked for generations, but their new product line has a design flaw. The plastic part that captures the outer burr is also used as a lower bearing for the inner burr, a terribly weak wear surface that creates unwanted play for course grind settings after only a few uses. This is apparently common to many conical burr grinders, but it need not be so!
Scouring the web for a way to remedy the loose burr problem affecting late-model Zassenhaus Coffee Grinders, I found just one set of instructions. Inspired by the suggestion to add a secondary bearing, I found a scrap piece of steel 1/32" (>1mm) thick to create a new bearing.
The new bearing sits flush between the burr and the bean hopper, and accepts the burr shaft with a 5/16" center hole (actual diameter 8mm I believe). The bearing plate is 65mm long by 15mm wide, with a screw hole spacing of 50mm. It is critical to center the middle hole 25mm from each screw hole, so that the burr will be centered.
To install, first disassemble the mill. Remove the four top screws and take out the top assembly. Remove the two burr holder screws. Unscrew the handle nut and unscrew the handle. Insert the new bearing and reassemble, adding small washers as required to make the new bearing sit evenly. Photo 3 shows notches made in the plastic to recess the screw heads, making more thread length available.
In testing, the additional bearing sometimes impedes the feed rate of beans a little, but a quick shake keeps them flowing. The bearing squeaks a little, so an improved version would use a brass sleeve to hold the burr shaft.
Happy grinding!
9 years ago on Introduction
I bought an old Zassenhaus Mokka on ebay and was not impressed at all buy the built quality. So I decided to redesign it. I also integrated the grind adjustment so there's nothing at the bottom of the burr (like the new ones). 2 Ball bearings (not installed when I took the pictures) keep it centered now. https://plus.google.com/112271286615938954540/posts/EB39Muhhsfh
