Introduction: Altoids PSP Recharger
This is my first instructable so don't judge too harshly. This project came to be when I thought "Hey, Sony is evil, they don't have any inexpensive alternatives to their battery packs" I find out now that other companies have made external battery packs (but what's the fun in buying one anyway!). So I set out on an epic journey to create an external battery pack for my PSP. Enjoy!
Step 1: Procure Components
first you'll need to get all of the parts and pieces.
1- altiods tin (flavor of your choice)
2- a +5 volt regulatora +5 volt regulator (what this whole project revolves around)
3- a dpdt switch or your choice (it should be pretty small)
4- a four AA battery holdera four AA battery holder
5- a LED for indicatora LED for indicator
6- a DC power connectora DC power connector (plugs into PSP)
7- mono phone plugmono phone plug
8- mono phone jackmono phone jack
9- 2 conducter speaker wire
10- various wires for connections
once you have that you're ready to go!
Step 2: Hack Battery Holder
when you buy the battery holder it will not fit in the tin, it was at this point when I thought "NOT COOL" and I went through an hour or two trying to make my own battery holder until at 11:00 I realized "WOW, I'm stupider than I thought!!!" and came to the realization that I could just cut out the center section of the original battery pack (or maybe I was just angry at it and wanted revenge the thing), it worked. It actually helps the lid close better so it won't fall open by accident.
once it's cut, go ahead and dry fit it, put it in, insert the batteries and push it as far to one end of the tin as you can then super glue it in
note on super glue: when using teh uberglue don't close the tin until it is completely dry or you will end up with the fumes drying onto the walls and you get the cloudy look that are in my pics, and also only glue in well ventilated areas so that you don't die
There I said it Now you can't sue me
Step 3: Assemble the Circuit
once the battery pack is installed and the glue has dried you can break out the soldering iron. It uses a extremely simple circuit and I should be able to discribe it, If you have trouble understanding or I just do a bad job of discribing it and the sketch doesn't help, just tell me and I can go more in depth. Here I go.
The output plug and the LED are wired in parallel (if they are in series, the LED will suck up too much voltage, I learned that the hard way) through the switch and the regulator, Just look at the sketch please
once you're done with soldering make sure there is no way that it will short because the whole thing will be crammed into a pretty small space in the end
ONWARD!!!
Step 4: Make the Connection and Go for a Spin!
Now to make the cord that connects the battery pack to the PSP.
cut a legth of your speaker wire (it doesn't really matter how long) and attach the two different plugs to each end make sure that the polarities work, the inside of the power connector needs to be positive and the outside negative.(I am not responsible for any fried PSPs, OK)
now, that you have the cord, make it look good, take it for a spin! this was featured in a recent MAKE: podcast but if you missed it, here's how,
Put one end of the cord in the chuck of your drill, hold the other end and let 'er rip, when you're done spin it backwards a little ways so that it doesn't coil up.
Step 5: Put It All Together!
now just drill the holes and install all of the parts in the tin, be careful not to scratch up the sides like I did, and have a good plan for the layout before you start to poke holes in your tin
Step 6: Conclusion
well, there you have it! in five easy steps, I highly recomend making one if you have a PSP but I will also sell them if someone wants one...
Coming Soon,
THE ALTOIDS EXTERNAL WI-FI ANTENNAE
it's a thing of beauty, eh?
67 Comments
11 years ago on Introduction
Thank you for the guide, but I found a much simplier solution to MY problem. I let my psp get completly out of juice, and I couldn't find the charger. So, I go online to find some re-charge solutions, and I foung this. I then dug through my old "spare parts" bin. And I found a 5v cell phone charger. So I took the Mono cord, and just soddered the two together. But I think you for your guide anyway.
11 years ago on Step 2
Interesting, but unrelated little fact, that may already be well known: The fumes are more or less adhering to the oil in your fingerprints, so that cloudiness is palm/fingerprints, I think members of law enforcement use similar methods to get fingerprints off of 'strange' surfaces
would it be possible to buy this or one off you?
here is my email
oldwiseblack-1234567@yahoo.co.uk
12 years ago on Introduction
I know this is an old 'ible, but I thought that I would say that the reason that it is around "4.7 volts" is because with voltage regulators need about a 2 volt extra overhead.
AI
14 years ago on Step 3
i followed all the directions and everything but i am geting no charge out of the jack
Reply 12 years ago on Introduction
if the orange light isn't lighting up on the PSP it probably is charging, but like he said, it is a bit under power.
yea i agree because i heard green leds take less power to light than other colors like orange wjite and blue
*white
that really does not make any sense cause it probably has a circuit that lights a orange led when charging the battery. you need a certain voltage or it wont go. i learned this with a little thing i made up for this. it was a salvaged 4 battery pack. i just snipped a usb charger cord and soldered the wires on the pack. when the batteries started to die, they where putting out less voltage(what happends typically when aa's "die" ) they got below the 5V minimum and it stopped charging. i checked it with a multimeter too. btw, you really dont need to put any kind of resistor on the batteries because 6V isnt really going to hurt it that bad, if you need a longer charge, just go with c or d batteries(both 1.5 volts, just more power)
Reply 13 years ago on Step 3
Yo same here but i used usb instaed of jack
me either...
13 years ago on Introduction
Dude its not charging in the picture (the red indicator light on the PSP is not on).
Reply 13 years ago on Introduction
if you read, he said it doesnt always register because it is a little below power. but also, if you look at the altoids tin its led is not on either.
13 years ago on Step 1
I would really highly recommend a diode to be included. Although it isn't essential, inserting the batteries backwards CAN AND WILL destroy the 5 volt regulator. This design marks the battery connections pretty well, but I used a battery pack connected with 9v terminals on my PDA/PSP/USB charger and my friend hooked the connector up backwards and fried the whole device. My new version with a diode eliminates this problem. Putting the diode between the batteries and the regulator means that power only flows one direction, preventing backwards flow that could destroy it.
Reply 13 years ago on Step 1
I just want to be safe when i finish mine up even tho this instructable doesnt work... the part w/o led and switch works... so what diode u reccomend .. plz post a link if u can ty
what diode do u recommend?
OKay. I made the charger diagram from the battery to the 5v reg to the usb ... that's the only parts that are recieving voltage from the batteries. idk what's wrong i have DPDT switch has 3 prongs and a led in a holder..... any ideas what im doing wrong plz reply
13 years ago on Step 6
is there a way i can make sure my wires for the dc connector from the phone jack have juice to them?
could you get a closeup of the circuit i am having a hard time knowing what to do i did it the way the diagram shows i think but i don't get a charging light at all.
no charge in the psp. is it because the regulator that you posted gives out 5V and only 1000mA? didn;t it need 2000mA? just asking.
