Introduction: 10 Basic Arduino Projects for Beginners! Make at Least 15 Projects With a Single Board!
About: Maker 101; Beginner and intermediate level Maker projects! You can find projects such as "How to" and "DIY" on programmable boards such as Arduino, ESP8266, ESP32 and Raspberry Pi on this channel. The projects…
Arduino Project & Tutorial Board;
  • Includes 10 basic Arduino projects.
  • All source codes, the Gerber file and more.
  • No SMD! Easy soldering for everyone.
  • Easy removable and replaceable components.
  • You can make at least 15 projects with a single board.
Step 1: Video Tutorial & Project List
See how it works! You can see all the steps of this project in this video.
  1. Enable the Buzzer and LED with the LDR
  2. Control the RGB LED with Potentiometers
  3. Play Ringtone with Buzzer and Button
  4. Enable the Buzzer and LED with the PIR
  5. Control the RGB LED with IR Remote
  6. Control the Servo Motor with IR Remote
  7. Control Multiple Servo with Potentiometer
  8. Humidity and Temperature indicator with DHT
  9. Temperature indicator with LM35 and OLED
  10. Control Multiple Servo via Bluetooth Slider App
Step 2: Required Hardware:
1x Nano V3 Board - http://bit.ly/2MHVDYi
1x Bluetooth Module - http://bit.ly/2D735b0
1x PIR Motion - http://bit.ly/2WAenxz
1x OLED I2C - http://bit.ly/2HIhQqf
1x DHT11 - http://bit.ly/2sZG84T
1x LM35 - http://bit.ly/2TsCvA6
1x LDR - http://bit.ly/2MPatwo
1x IR Infrared - http://bit.ly/2TpVBH3
1x RGB Module - http://bit.ly/2BfFzZc
1x Buzzer - http://bit.ly/2Soa0X2
2x Potentiometer - http://bit.ly/2GeU4zQ
2x Potentiometer Knob - http://bit.ly/2DOijDw
2x Push-Button - http://bit.ly/2Wx1xjL
Female Header - http://bit.ly/2MJtnVm
Resistor Kit - http://bit.ly/2GlmUil
Optional Equipment:
Soldering Tool Kit - http://bit.ly/2D6YbuC
Soldering Stand - http://bit.ly/2RuweC9
Wire Cable Cutter - http://bit.ly/2P5FJXA
Step 3: Download Gerber File & Order PCB
  • Download the Gerber (PCB design) file.
  • Go to https://www.pcbway.com/ (I explained why I selected the "PCBWay service" below.)
  • Click "Quote & Order"
  • Only a few information will be entered in the "PCB specifications" field. All other settings will be default.
    • PCB Size: 114 x 91 mm
    • Quantity (minimum) : 5pcs
    • Layers: 2 Layers
    • Solder Mask (PCB Color): Green
    • Silkscreen (Text Color): White
    • Under "Surface Finish" selection: Yes
    • Click "Calculate"
    • Build Time : 1-2 days / Qty: 5 / PCB Cost: $27
    • You can select any Shipping Way
    • Click "Add to Cart"
  • Upload the Gerber file
  • Wait review (All your orders will be receiving a free engineering file review service from PCBWay trained and professional technicians before you pay in the most timely manner.)
Why PCBWay?
  • When things go wrong, they are always extremely helpful.
  • They actually tested every single board at no extra cost.
  • Quality. I've never been disappointed.
  • No hidden fees. What you pay is what you see in the invoice.
  • You may order minimum 5pcs PCB.
  • Suitable for many customers who are price-sensitive like students, hobbyists and makers.
  • You may choose DHL and other courier services for the balance of speed and budget.
  • You will get extremely prompt responses via emails and chat during working hours.
Bonus: Get $5 New User Free Credit
Step 4: Soldering
  • No SMD soldering! Easy soldering for students, teachers, hobbyists and makers.
  • All component names and locations marked on the PCB.
Step 5: Assembly
  • All component locations are specific on PCB.
  • All components are connected to separate pins. Therefore, each component can communicate with one another at the same time.
  • Do not forget to remove the Bluetooth Module when uploading code!
Step 6: 10 Basic Arduino Projects for Beginners!
  9. Temperature indicator with LM35 and OLEDControl
  10. Multiple Servo via Bluetooth Slider App
Download: http://bit.ly/2Bf67tH
  • All source code
  • All required libraries
  • All pin numbers to which the components are connected
Important: Don't forget to remove the Bluetooth Module when uploading code!
