Introduction: Beebeecraft Tutorials on How to Make Flower Resin Earrings
Summary: Do you want to get a concise flower earrings? It can be matched with many vogue clothing style. By following this tutorial, you can learn how to make a flower resin earrings . Let’s start it!
Step 1: Materials and Tools Needed for the Flower Resin Earrings:
UV Glue Curing by LED UV Lamp, Black
13.5x7x3cm Ear Stud Components, Mixed Color
4mm Glass Pearl Beads Strands, White, Hole: 0.8~1mm
4~10x0.7x1mm Iron Jump Rings , golden
Purple color essence
UV lamp
Tape
Container
stirring rod Flat nose pliers
Round nose pliers
Step 2: Instructions on How to Make the Flower Resin Earrings:
1st, twist the jump ring into a petal shape, and place them into a flower shape on a plastic piece.
2nd, mix purple color essence with the UV glue , adjust it to the color what you like. Add them into the jump rings.
Step 3:
3rd,wait until the small bubbles in the glue disappear, put the flower under UV lamp slowly for a few minutes, till the glue harden.
4th, add a little UV glue in the center of the flower, then put a pearl bead on it. Bake it under the UV lamp for a few minutes.
5th , take it out again, add the ear stud components on the back, then bake for a few minutes till it harden. Now we finished it!
Step 4: The Final Look Is Like This:
So far the tutorial of making flower resin earrings is completed! Do you also think you can finish them alone? It is very easy,you can create so many shape of earrings with your imagination! Share me your some nicer ideas then. Welcome to find more jewelry making supplies on Beebeecraft!
