Introduction: Blu - LED's
There are so many instructables on the web , but this is the most simplest and easiest to upgrade further !!
Step 1: Setting Up Circuit Connections !!
- Set up the led connection as shown in diagram !!
- Skip to step 3 and come back again !
- Connect Bluetooth after uploading the program !!
NOTE : Please connect the Bluetooth module as directed :
RX of Bluetooth module goes to TX of arduino board!
TX of Bluetooth module goes to RX of arduino board!
You are almost done !!
Download the app , to control your project !!
Connect to the app and bingo , you are done !!
Step 2: Copy the Program Here !!
/* ©Compiler Bro's */ #defineledPin8// Intially define the state to be zero! int state= 0; voidsetup(){// put your setup code here, to run once://Set up a communication between arduino and your systemSerial.begin(9600);Serial.println("Connected!!");pinMode(ledPin,OUTPUT);digitalWrite(ledPin,LOW);}voidloop(){// put your main code here, to run repeatedly:if(Serial.available()>0){state=Serial.read();}if(state=='A'){digitalWrite(ledPin,LOW);Serial.println("LED : OFF");state=0;}elseif(state=='B'){digitalWrite(ledPin,HIGH);Serial.println(" LED : ON");state=0;}}
