Introduction: Bluetooth Wireless LCD Data Transfer
This application will tell us the data transfer via bluetooth to the LCD screen.
Arduino-based system has a temperature sensor LCD screen will project the other system. Data from the system we can track the status of the LCD screen instantly transferred to the system.
More information : lcd temperature bluetooth
Step 1: Materials:
- 2 x Arduino
- Hc-05 Bluetooth Module
- Hc-06 Bluetooth Module
- LM35 Temperature Sensor
In our project, you need to set the Bluetooth module AT commands will communicate primarily for two bluetooth module.
You can see how this is done from the link below.
http://www.robimek.com/hc-05-ile-hc-06-bluetooth-modullerin-haberlesmesi/
Step 2: Transmitter Circuit:
Step 3: Receiver Circuit:
Step 4: Receiver Software:
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define BT_SERIAL_TX 6
#define BT_SERIAL_RX 7
SoftwareSerial BluetoothSerial(BT_SERIAL_TX, BT_SERIAL_RX);
char temp= ‘ ‘;
void setup()
Serial.begin(9600);
lcd.begin(16, 2);
lcd.print(“room temp:”);
BluetoothSerial.begin(9600);
void loop()
if (BluetoothSerial.available()>0)
temp= BluetoothSerial.read();
lcd.setCursor(0, 1);
lcd.print(temp);
lcd.print(” degree”);
delay(100);
Step 5: Transmitter Software:
#include
int tempsensor= 0;
int val;
int temp;
void setup()
Serial.begin(9600);
void loop()
val= analogRead(tempsensor);
temp= map(val, 0, 205, 0, 100);
BluetoothSerial.print(temp);
delay(100);
Shelving Contest
