Introduction: Box Suit DAMBOL
I made a robot costume with cardboard.
It is decorated with LED tape.
Step 1: Leg Making
Cut the cardboard and assemble it, fix the microcomputer, battery, switch inside with glue gun.
To increase the strength paint the surface with adhesive and dry. It gets transparent as it dries and looks like a varnish.
It is completed by covering old boots.
Step 2: Leg Circuit Configuration
Parts
- Arduino Pro Mini 5V/16MHz
LED tape NeoPixel
Power switch
9V battery
Step 3: Leg Arduino Code
LED shake brightness with random number, so that it blinks twinkle.
#include <adafruit_neopixel.h> #ifdef __AVR__ #include <avr power.h=""> #endif #define PIN1 A3 #define PIN2 A2 Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(30, PIN1, NEO_GRB + NEO_KHZ800); Adafruit_NeoPixel strip2 = Adafruit_NeoPixel( 7, PIN2, NEO_GRB + NEO_KHZ800); //Flickering LEDs with random numbers<br>int lumMin = 30; float lum[30] = {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}; unsigned long interval = 0; void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code strip1.begin(); strip2.begin(); strip1.setBrightness(45); strip2.setBrightness(45); strip1.show(); // Initialize all pixels to 'off' strip2.show(); } void loop() { if (millis() - interval > 100) { interval = millis(); for(int i=0; i < strip1.numPixels(); i++){ lum[i] = (float)(random(lumMin, 101)/100.0); } } //LED ON for(int i=0; i < <strip1.numpixels(); i++){ strip1.setpixelcolor(i, strip1.color(255 * lum[i], 0, 0)); strip2.setPixelColor(i, strip1.Color(255 * lum[i], 255 * lum[i], 255 * lum[i])); } strip1.show(); strip2.show(); }
Step 4: Arm Making
Make a box with a hole through which hands pass through with cardboard, fix the parts inside and complete the LED tape.
LED tapes can shine white.
Like the feet, apply the adhesive on the surface and dry it.
Step 5: Arm Circuit Configuration
Parts
- Digispark
- LED tape NeoPixel
- Power switch
- 9V battery
Step 6: Arm Arduino Code
I like to shoot my LEDs with random numbers as well as feet.
#include <adafruit_neopixel.h> #ifdef __AVR__ #include <avr power.h=""> #endif #define PIN1 0 Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(9, PIN1, NEO_GRB + NEO_KHZ800); //Flickering LEDs with random numbers int lumMin = 30; float lum[9] = {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}; unsigned long interval = 0; void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code strip1.begin(); strip1.setBrightness(45); strip1.show(); // Initialize all pixels to 'off' } void loop() { if (millis() - interval > 100) { interval = millis(); for(int i=0; i < strip1.numPixels(); i++){ lum[i] = (float)(random(lumMin, 101)/100.0); } } //LED ON for(int i=0; i < strip1.numPixels(); i++){ strip1.setPixelColor(i, strip1.Color(255 * lum[i], 255 * lum[i], 255 * lum[i])); } strip1.show(); }
Step 7: Head Making
Cut off the creation with cardboard, fix the parts inside and assemble, paste the LED tape and wire it to the microcontroller.
For fixing to the head, fix the rubber string and transparent PVC hemisphere with glue gun.
Step 8: Head Circuit Configuration
Parts
- Adafruit Trinket 3.3V
- LED tape NeoPixel
- Power switch
- 9V battery
- Transparent vinyl chloride hemisphere
Step 9: Head Arduino Code
I make the first and last five LED tapes of 14 cells white, and the middle four shine red.
#include <adafruit_neopixel.h> #ifdef __AVR__ #include <avr power.h=""> #endif #define PIN1 0 Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(14, PIN1, NEO_GRB + NEO_KHZ800); //Flickering LEDs with random numbers int lumMin = 30; float lum[14] = {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}; unsigned long interval = 0; void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code strip1.begin(); strip1.setBrightness(45); strip1.show(); // Initialize all pixels to 'off' } void loop() { if (millis() - interval > 100) { interval = millis(); for(int i=0; i < strip1.numpixels(); i++){ lum[i]="(float)(random(lumMin," 101)="" 100.0); } } //LED ON for(int i = 0; i < strip1.numpixels(); i++){ strip1.setPixelColor(i,strip1.color(255 * lum[i], 255 * lum[i], 255 * lum[i])); } for(int i = 5; i < 9; i++){ strip1.setPixelColor(i, strip1.Color(255 * lum[i], 0, 0)); } strip1.show(); }
Step 10: Body Making
I made it with cardboard as well.
The upper part was opened so we could fix the Velcro with the shoulder.
Step 11: Body Circuit Configuration
Parts
- Adafruit Pro Trinket 3V/12MHz
- LED tape NeoPixel
- Power switch
- 9V battery
Step 12: Body Arduino Code
#include <adafruit_neopixel.h> #ifdef __AVR__ #include <avr power.h=""> #endif #define PIN1 A5 #define PIN2 A4 #define PIN3 A3 #define PIN4 A2 Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(36, PIN1, NEO_GRB + NEO_KHZ800); Adafruit_NeoPixel strip2 = Adafruit_NeoPixel( 10, PIN2, NEO_GRB + NEO_KHZ800); Adafruit_NeoPixel strip3 = Adafruit_NeoPixel( 15, PIN3, NEO_GRB + NEO_KHZ800); Adafruit_NeoPixel strip4 = Adafruit_NeoPixel( 18, PIN4, NEO_GRB + NEO_KHZ800); //Flickering LEDs with random numbers int lumMin = 30; float lum[36] = {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}; unsigned long interval = 0; void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code</p><p> strip1.begin(); strip2.begin(); strip3.begin(); strip4.begin(); strip1.setBrightness(45); strip2.setBrightness(45); strip3.setBrightness(45); strip4.setBrightness(45); strip1.show(); strip2.show(); // Initialize all pixels to 'off' strip3.show(); strip4.show(); } void loop() { if (millis() - interval > 100) { interval = millis(); for(int i=0; i<strip1.numpixels(); i++){ lum[i] = (float)(random(lumMin, 101)/100.0); } } //LED ON for(int i = 0; i < strip1.numpixels(); i++){ strip1.setpixelcolor(i, strip1.color(255 * lum[i], 0, 0)); } for(int i=14; i<22; i++){ strip1.setPixelColor(i, strip1.Color(255 * lum[i], 255 * lum[i], 0)); } for(int i = 0; i<strip2.numpixels(); i++){ strip2.setPixelColor(i, strip1.Color(255 * lum[i], 255 * lum[i], 0)); } for(int i=0; i < <strip3.numpixels(); i++){ strip3.setpixelcolor(i, strip1.color(0, 0, 255 * lum[i])); } for(int i=0; i < strip4.numPixels(); i++){ strip4.setPixelColor(i, strip1.Color(0, 0, 255 * lum[i])); } for(int i=7; i<11; i++){ strip4.setPixelColor(i, strip1.Color(255 * lum[i], 255 * lum[i], 0)); } strip1.show(); strip2.show(); strip3.show(); strip4.show(); }
Halloween Contest 2018
