Introduction: Bubble Brass Ring, the Piercing Saw Method - 6 Steps
About: Hello world! Pharmacy student here! And I make things. I also bully my gf into managing my SN presence, so here we are. I will show you my homemade projects and crafts! Cheers!
Hello guys I'm new to this and my laptop is really slow so for this one I guess I'll have to improvise. I promise next time I'll shoot more photos during the video! Feel free to ask me anything about the procedure, materials or anything I ommited
For this ring I used:
  • 85/15 brass sheet
  • Iris jeweller's saws
  • A drill with 1mm point
  • A piercing saw
  • Wax
  • Various files
  • A ring mandrel
  • A propane flame torch
  • Silver 50% solder wire 0.7mm
  • Borax soldering paste
  • A grinding wheel for polishing with a brass wire round brush and a cotton round brush
  • Yellow abrasive paste for brass
  • A wooden hammer
Step 1: Designing the Bubbles and Drilling
So I first got the brass sheet and hand traced the bubbles with a permanent marker. I made sure the design was long enough to make a 17-18 size ring. I then made holes with a fine (1mm) drill to help with cutting the internal parts.
Step 2: Cutting the Bubbles
I then went on to cut out the design with a piercing saw wearing Iris Jeweller's saws (my favourite). (keep in mind you'll have to lubricate the saw with wax to avoid breaking it)
Step 3: Filing
Once cut, I carefully filed every edge. To file successfully you'll have to do it one way without pressing the file on the metal, it takes time...I know but the result pays! I used three different sized files for convenience and to be able to reach every spot
Step 4: Rounding the Ring
Afterwards I rounded the ring on the mandrel by hand (the metal is quite malleable) and put the edges together.
Step 5: Soldering
For the soldering I use a borax soldering paste I make with borax powder and distilled water, this paste is an antioxidant and without it soldering brass is almost impossible. So I give a generous dab of borax paste.
To solder with a propane flame torch you have to warm up the brass untill is red hot and then go in with the silver solder wire touching the edge meeting point for a fraction of a second. Then I just dump it in water to cool it off.
Step 6: Polishing
So now the ring is quite almost complete, the only step missing is the polishing.
I go in and do the first round without any paste just to clean off the soldering point and excess borax on a brass wire round brush.
Then I put the ring on the mandrel and hammer it lightly all over to harden the metal before the final polishing round.
I then put some abrasive paste for brass polishing on the cotton round brush l and go in to polish the ring till it's quite actually a mirror. And that's it.
Step 7: This Is Not Really a Step But the Final Result!
This is not really a step, it's the end result and a video of how to do it! Let me know if you liked it and show me your crafts! I'm open to critics!
Stay home, stay safe
