Introduction: Classic Joystick to USB Adaptor
If you grew up in the early 1980’s and were into video games, you probably had an Atari 2600, ColecoVision, or similar game console. The controllers or joysticks for each of these systems had a distinct feel that is different from today’s game consoles or PC game controllers. If you find yourself longing to plug your old ColecoVision or Atari 2600 joystick into your modern PC, but are not sure how to go about it, this project is for you.
I designed this Classic Joystick to USB Keyboard Adapter with the ADAMEm ColecoVision and Coleco ADAM emulator in mind (http://www.komkon.org/~dekogel/adamem.html, which can be run in Microsoft Windows using Virtual ADAM http://www.sacnews.net/adamcomputer/downloads/). However it will work with most emulators and any game or program that can use the keyboard as input. I have also tested it with the following emulators:
- blueMSX (ColecoVision, MSX, and others) - http://www.bluemsx.com/
- Stella (Atari 2600) - http://stella.sourceforge.net/
The following classic game console controllers are support:
- Atari 2600
- ColecoVision
- Coleco ADAM
- ColecoVision Super Action Controller (Spinner is not currently supported)
Step 1: What You Need
- Arduino Leonardo - http://arduino.cc/en/Main/ArduinoBoardLeonardo or Arduino Micro - http://arduino.cc/en/Main/ArduinoBoardMicro
- 9-Position HD Male D-Sub Connector - http://www.radioshack.com/product/index.jsp?productId=2102497 or equivalent
- Wire
- Classic Console Joystick
Step 2: Hardware
Connect the pins of the D-Sub Male 9 Position connector to the pins of the Arduino Leonardo or Arduino Micro as shown in the table.
Step 3: Software
The following Arduino Sketch file should be compiled and uploaded into the Arduino Leonardo or Arduino Micro: JoystickToKeyboard.ino
<p>// ColecoVision / ADAM Joystick to PC Keyboard Converter<br>// for the Arduino Leonardo
// 2014-08-24
//-----------------------------------------------------------------------------</p><p>// Joystick Pins
const byte gcFirePin = 2;
const byte gcUpPin = 3;
const byte gcDownPin = 4;
const byte gcLeftPin = 5;
const byte gcRightPin = 6;
const byte gcModeAPin = 7;
const byte gcModeBPin = 8;
const byte gcFireMonitorPin = 13;
const byte gcBit0Pin = 3;
const byte gcBit2Pin = 4;
const byte gcBit3Pin = 5;
const byte gcBit1Pin = 6;</p><p>// Keyboard Keys
const char gcUpKey = KEY_UP_ARROW;
const char gcDownKey = KEY_DOWN_ARROW;
const char gcLeftKey = KEY_LEFT_ARROW;
const char gcRightKey = KEY_RIGHT_ARROW;
const char gcLeftFireKey = KEY_LEFT_ALT;
const char gcRightFireKey = KEY_LEFT_CTRL;
const char gcPurpleButtonKey = KEY_LEFT_SHIFT;
const char gcBlueButtonKey = 'z';
const char gcAsteriskKey = '-';
const char gcPoundKey = '=';</p><p>// Current Frame Joystick Status
byte gLeftFireButton = 0;
byte gRightFireButton = 0;
byte gUp = 0;
byte gDown = 0;
byte gLeft = 0;
byte gRight = 0;
char gNumPadValue = ' ';
byte gPurpleButton = 0;
byte gBlueButton = 0;
byte gBit0 = 0;
byte gBit1 = 0;
byte gBit2 = 0;
byte gBit3 = 0;</p><p>// Last Frame Joystick Status
byte gLastLeftFireButton = 0;
byte gLastRightFireButton = 0;
byte gLastUp = 0;
byte gLastDown = 0;
byte gLastLeft = 0;
byte gLastRight = 0;
char gLastNumPadValue = ' ';
byte gLastPurpleButton = 0;
byte gLastBlueButton = 0;</p><p>// Line Read Variables
const unsigned int gcThreashold = 4;
unsigned int gLeftFireCount = 0;
unsigned int gRightFireCount = 0;
unsigned int gUpCount = 0;
unsigned int gDownCount = 0;
unsigned int gLeftCount = 0;
unsigned int gRightCount = 0;
unsigned int gBit0Count = 0;
unsigned int gBit1Count = 0;
unsigned int gBit2Count = 0;
unsigned int gBit3Count = 0;</p><p>// Frame Variables
const int gcFrameLength = 10;
unsigned int gLoopsPerFrame = 0;
unsigned long gLastFrameStart = 0;</p><p>// Shows the status of the joystick.
void ShowJoystickStatus()
// Debug Information
// Serial.println(gLoopsPerFrame);</p><p> digitalWrite(gcFireMonitorPin, gLeftFireButton | gRightFireButton);
}</p><p>void SendKeyboardStateToPc()
if ((gLastNumPadValue != ' ') && (gLastNumPadValue != gNumPadValue))
Keyboard.release(gLastNumPadValue);
if ((gNumPadValue != ' ') && (gLastNumPadValue != gNumPadValue))
Keyboard.press(gNumPadValue);
SendLineStateToPc(gLastLeftFireButton, gLeftFireButton, gcLeftFireKey);
SendLineStateToPc(gLastRightFireButton, gRightFireButton, gcRightFireKey);
SendLineStateToPc(gLastUp, gUp, gcUpKey);
SendLineStateToPc(gLastDown, gDown, gcDownKey);
SendLineStateToPc(gLastLeft, gLeft, gcLeftKey);
SendLineStateToPc(gLastRight, gRight, gcRightKey);
SendLineStateToPc(gLastPurpleButton, gPurpleButton, gcPurpleButtonKey);
SendLineStateToPc(gLastBlueButton, gBlueButton, gcBlueButtonKey);
}</p><p>void SendLineStateToPc(byte lastState, byte currentState, char keyUsedForLine)
if ((lastState == 1) && (currentState == 0))
Keyboard.release(keyUsedForLine);
if ((lastState == 0) && (currentState == 1))
Keyboard.press(keyUsedForLine);
}</p><p>unsigned int CheckJoystickLine(byte pin)
return (digitalRead(pin) == LOW);
}</p><p>void CheckJoystickLines()
const int cLineDelay = 50;
// Put Joystick in Direction Mode
digitalWrite(gcModeAPin, HIGH);
digitalWrite(gcModeBPin, LOW);
delayMicroseconds(cLineDelay);
gLeftFireCount += CheckJoystickLine(gcFirePin);
gUpCount += CheckJoystickLine(gcUpPin);
gDownCount += CheckJoystickLine(gcDownPin);
gLeftCount += CheckJoystickLine(gcLeftPin);
gRightCount += CheckJoystickLine(gcRightPin);</p><p> // Put Joystick in Keypad Mode
digitalWrite(gcModeAPin, LOW);
digitalWrite(gcModeBPin, HIGH);
gRightFireCount += CheckJoystickLine(gcFirePin);
gBit0Count += CheckJoystickLine(gcBit0Pin);
gBit1Count += CheckJoystickLine(gcBit1Pin);
gBit2Count += CheckJoystickLine(gcBit2Pin);
gBit3Count += CheckJoystickLine(gcBit3Pin);
}</p><p>void ResetFrameVariables()
// Copy Current Frame to Last Frame
gLastNumPadValue = gNumPadValue;
gLastLeftFireButton = gLeftFireButton;
gLastRightFireButton = gRightFireButton;
gLastUp = gUp;
gLastDown = gDown;
gLastLeft = gLeft;
gLastRight = gRight;
gLastPurpleButton = gPurpleButton;
gLastBlueButton = gBlueButton;
// Reset Frame Loop Counter
gLoopsPerFrame = 0;
// Reset Joysick State
gLeftFireCount = 0;
gUpCount = 0;
gUp = 0;
gDownCount = 0;
gDown = 0;
gLeftCount = 0;
gLeft = 0;
gRightCount = 0;
gRight = 0;
gBit0Count = 0;
gBit0 = 0;
gBit1Count = 0;
gBit1 = 0;
gBit2Count = 0;
gBit2 = 0;
gBit3Count = 0;
gBit3 = 0;
gNumPadValue = ' ';
gPurpleButton = 0;
gBlueButton = 0;
}</p><p>byte DetermineJoystickLineValue(unsigned int pressCount)
return (pressCount >= gcThreashold);
}</p><p>void DetermineJoystickValues()
const char cKeypadValueLookup[16] = {
' ', '6', '1', '3', '9', '0', gcAsteriskKey, ' ',
'2', gcPoundKey, '7', ' ', '5', '4', '8', ' '};
gLeftFireButton = DetermineJoystickLineValue(gLeftFireCount);
gRightFireButton = DetermineJoystickLineValue(gRightFireCount);</p><p> gUp = DetermineJoystickLineValue(gUpCount);
gDown = DetermineJoystickLineValue(gDownCount);
gLeft = DetermineJoystickLineValue(gLeftCount);
gRight = DetermineJoystickLineValue(gRightCount);
gBit0 = DetermineJoystickLineValue(gBit0Count);
gBit1 = DetermineJoystickLineValue(gBit1Count);
gBit2 = DetermineJoystickLineValue(gBit2Count);
gBit3 = DetermineJoystickLineValue(gBit3Count);
int keypadCode = (gBit3 << 3) + (gBit2 << 2) + (gBit1 << 1) + gBit0;
gNumPadValue = cKeypadValueLookup[keypadCode];
// Check for SuperAction Controller Buttons.
if (keypadCode == 7)
gPurpleButton = 1;
if (keypadCode == 11)
gBlueButton = 1;
}</p><p>void setup()
// Setup Serial Monitor
// Serial.begin(19200);
// Setup Joystick Pins
pinMode(gcFirePin, INPUT_PULLUP);
pinMode(gcUpPin, INPUT_PULLUP);
pinMode(gcDownPin, INPUT_PULLUP);
pinMode(gcLeftPin, INPUT_PULLUP);
pinMode(gcRightPin, INPUT_PULLUP);
pinMode(gcModeAPin, OUTPUT);
pinMode(gcModeBPin, OUTPUT);
pinMode(gcFireMonitorPin, OUTPUT);
}</p><p>void loop()
unsigned long currentTime;
currentTime = millis();
if (currentTime >= (gLastFrameStart + gcFrameLength))
// Do Joystick Value Commit Logic
DetermineJoystickValues();
// Send Values to Monitor
ShowJoystickStatus();
// Send Keyboad State to the PC
SendKeyboardStateToPc();
// Reset Frame Variables
ResetFrameVariables();
// Time to start next frame
gLastFrameStart = currentTime;
else
// Check the value of the input lines and make note of them.
gLoopsPerFrame++;
CheckJoystickLines();
}</p>Step 4: Default Keyboard Mappings
By default the classic console joystick to USB keyboard adapter uses the mappings shown in the table (these are the default mappings used by the ADAMEm emulator). These mappings can be changed by altering the Arduino sketch file provided (see the Keyboard Keys section).
Step 5: Additional Details
Additional details on the nuances of reading values from Atari 2600 and ColecoVision controllers can be found on my blog entry at http://mheironimus.blogspot.com/2014/09/arduino-classic-joystick-to-usb-adaptor.html.
