Introduction: DIY Amazing Led Animation for Any 230v Light
About: I like to make diy electronics,electrical and life hacks projects.
Hello everyone,
Today I will show you how you can make a Triac control 230v 16000 watts animated led lighting
In this project we will use triac with arduino to control the led light.
In this project I wanna thank to " LCSC.COM " for providing me the necessary components..
They provide a lot of electronics components at very cheap rate.
Also they provide components datasheet.....
So let's do it .......
Step 1: Watch the Video
Step 2: Components Required
1. Arduino uno……….https://goo.gl/6u9b6b
2. BT136 triac*16 …………….https://goo.gl/ZD1t4g
3. moc3021*16 optocoupleric*16……https://goo.gl/X2d4X7
4. 74hc595 *2 shift registor ic…………..https://goo.gl/72BRd9
5. 220 ohms resistor*32….1/4 watts………..https://goo.gl/UcL7PT
6. 28 pin ic base(optional)……….https://goo.gl/Eirx5k
7. 16 pin ic base(optional*2……….https://goo.gl/6hjVqg
8. 6 pin ic base(optional)*16………..https://goo.gl/171wgH
9. 5v power supply……(like mobile charger)….
10. universal pcbs*4………https://goo.gl/Bp8baL
11. 16 mhz crystal……..https://goo.gl/UD9pc6
12. 22pf*2………https://goo.gl/adxYxd
13. 10k resistor….1/4 watts………https://goo.gl/QZYBCG
14. 1000 uf capacitor/25v…………https://goo.gl/26gSgv
15. 230v ac power cable……….
16. 220v led light*16……….
17. Terminal Blocks*18……https://goo.gl/2xqJq9
Step 3: Order the Components
As I told earlier..LCSC.COM one of the largest electronics components supplier in China...
  • They provide the components worldwide.....
  • Here are some best thing about LCSC.COM
  • A lot of components available
  • Price is very cheap
  • 4$ off at first order
  • Fast delivery, Very good packaging for every components with details
  • Also they provide components “Datasheet” , So you don’t need to find Datasheet at different website.
Step 4: Circuit Diagram
Step 5: Assemble the Circuit
Step 6: Caution
“Please Do not Touch any component while the circuit is plugged in. The circuit is directly connected to 220v ac supply.This can give you badly shock. Do it as your own Risk. I/HowToBro will not be responsible for any unwanted situation.”
Step 7: Done
Now you are done....
You can use it anywhere you want....just connect the leds and enjoy your project....
Step 8: Thank You
Thank you everyone ....
I hope you will like this project... You can watch my youtube channel for more updates ..... Also you can visit my website...www.electroakash.com
