Introduction: DIY INSTRUCTABLE ROBOT
TO MAKE THIS INSTRUCTABLE
YOU WILL NEED
BALSA WOOD
GLUE/GUN
PAPER CLIP
UTILITY KNIFE
WIRE CUTTER
AND A PERMANENT MARKER
Step 1: LETS MAKE IT
FIRSTLY THE HEAD, CUT A BLOCK OFF YOUR CHOSEN WOOD, 1/2 INCH WIDE AND 3/4 INCH HIGH
GRAB YOUR PAPER CLIP OPEN IT UP,USING YOUR WIRE CUTTER CUT ABOUT 1 & 1/2 INCH OFF
CUT THE PAPER CLIP THAT HAS BEEN CUT OFF, AT EACH END AT AN ANGLE
NOW PUSH THE WIRE THROUGH THE MIDDLE OF THE BLOCK OF BALSA WOOD
CUT 1 & 1/2 INCH BY 1 INCH OFF YOUR BALSA WOOD FOR THE BODY
GLUE THE HEAD ONTO THE BODY
FOR THE ARMS, CUT A THIN 2,MM BY 1 INCH LONG PIECE OF WOOD (USING THE UTILITY KNIFE) CUT THE TIPS OF THE ARM FOR HANDS, THEN GLUE AT AN ANGLE THE ARM 5 CM DOWN THE BODY.
FOR THE LEGS 3/4 INCH LONG BY 10,MM WIDE WOOD , AND GLUE TO THE BODY
USE 3 SMALL PIECES OF WOOD AND COLOUR BLACK THEN GLUE TO THE FRONT OF THE BODY
CUT 1 INCH LONG AND THIN WOOD ,AND GLUE UNDER THE 3 BLACK BITS OF WOOD.
DRAW A LINE FOR THE MOUTH USING BLACK MARKER
FOR THE EYES 2 TINY BITS OF WOOD COLOURED RED , MAKE ONE EYE SLIGHTLY LONGER,THEN GLUE
EARS 2 BITS OF WOOD MARKED RED,THEN PUSH ONTO THE WIRE WITH GLUE
THEN COLOUR THE REST WHAT EVER COLOUR YOU LIKE
AND THAT IS THAT.
PLEASE BE CAREFUL ESPECIALLY WHILST USING THE KNIFE.
SORRY THERE IS NO VIDEO
BUT MY NEXT PROJECT WILL HAVE VIDEOS.
HAVE A GREAT XMAS
AND HAPPY CRAFTING
Step 2:
FINAL PIECE
NAME YOUR ROBOT
MY ROBOTS NAME IS
KENDO
THE END
