Introduction: EYE OF HORUS INLAY
About: In my shop I have a name for hammer, saw, and plier. The saw is Tess, the hammer's Joe, and Glumdalclitch is the plier. Yes, I'm brillig, and my slithy toves still gyre and gimble in the wabe. With that, le…
This is my first attempt at inlay.
During the Vietnam era I spent 4 years in the Navy. I never got a tattoo. My youngest son who is in his 30s has several. One is the Eye Of Horus. I wanted to try this design as an inlay. Eventually, what I created will probably become something else like a box lid. We'll see.
Step 1: TOOLS
Basically, I used the scroll saw. The miter saw was only used to cut wood into manageable sizes. The mallet was used to drive home the inlay. The sanding station was a big time saver from hand sanding everything.
Step 2: MATERIALS
I found a piece of 1/2" oak ( 5.5 x 11.75) left over from the chess board and box I made. The purple wood (most likely called purple heart?) was from a box of hardwood cut offs gifted to me by the tattooed son for father's day.
Step 3: PREPARING THE IMAGE FOR SCROLLING
I glued the image on the oak and the copies of the image on the purple heart. I drilled holes through which to feed the scroll saw blade for interior cuts. Yes, I over drilled holes. I only needed one per section.
Step 4: CUTTING THE OAK FIRST
I decided to cut the background first. I cut away all the image and left the void. Then I sanded off the paper. Ok, so far.
NOTE: My best advice to those attempting scroll saw work is to cut slowly. Very, very slowly. Luckily, I've got that type of personality that enjoys detailed work.
Step 5: CUTTING OUT THE IMAGE
Not one piece fit perfectly. So, more meticulous work gently sanding each piece until it fit. Yes, the pieces were delicate. Yes, one did snap. Yes, I praised the glue gods for giving me the means to reattach it.
Step 6: GLUING AND SANDING
After gluing the pieces in the voids I notices gaps. I mixed sawdust with glue and filled them. Then gave it a thorough sanding.
Step 7: TUNG OIL FINISH
I DID MAKE IT INTO A COVER FOR A GIT BOX I finished with Tung Oil and set it aside to await the net step in it's life.
Step 8: THANKS FOR STOPPING BY
I hope you enjoyed this Instructable as much as I did creating this inlay. This was my second scroll saw project and cutting was easier -- as is the case with any repetitive task. It has given me a true admiration for those adept at inlay and marquetry. And, as usual, all comments are welcome and all questions are answered.
KJ
