Introduction: Edible Cinnamon Embers
About: Hands-on DIY lover and borderline crazy crafter. I love Halloween and creepy food.
We've bid farewell to Halloween and now we're heading towards Christmas at high speed. If you're already making your list of gifts to give and have a few friends on it who qualify as 'naughty,' these coal black coated candy sweet-treats are a great way to tell them you're onto their shenanigans!
With a sweet honeycomb center and a hint of cinnamon, these edible cinnamon embers look like you just pulled them out of the fire.
Bonus: they're much tastier than real coal.
  • 5 cups white sugar, divided
  • 2/3 cup light corn syrup
  • 1/3 cup water
  • 4 teaspoons baking soda
  • Small bottle of cinnamon oil
  • Red food coloring
  • Black food coloring
  • 2 cups black candy melt
  • Black sanding sugar (optional)
Step 1: Mixing Up the Honeycomb Center
Start by first lining a 9X13″ baking pan with parchment paper. Set aside for now.
Now go find a pot…a big one. Bigger than you think you’re going to need. While this recipe is less than 4 cups of liquid combined in the pot while cooking, we’re going to throw a little science into the mix at the end and foam up the final product, so you’re going to want a pot that is at least twice as high as the amount of liquid you are putting into it.
In your huge-ass pot (yes, that’s the technical term), combine together 2 1/2 cups of your sugar with your 2/3 cup corn syrup and 1/3 cup water.
Over medium heat, stir this mixture until all the sugar is dissolved.
Once the sugar is dissolved, clip on a candy thermometer and raise up the heat on your stove to medium-high.
Continue stirring until the candy starts to boil.
Step 2: It's Alive!
Once it boils, STOP STIRRING!
Watch the pot as it boils, occasionally brushing down the sides with a wet pastry brush dipped in water to get rid of sugar crystals.
Once the sugar reaches 300F/148C, remove from heat and immediately add your red food coloring and cinnamon oil flavoring.
WARNING #1: Cinnamon oil can be very strong so just add a few drops or so. You really won't need much to flavor the entire batch. Too much and you'll run the risk of the cinnamon overwhelming everything, including your tastebuds.
WARNING #2: When you add in your food coloring and flavoring, it’s going to steam. Don’t breathe that cloud in or get it in your eyes, it’s gonna hurt like a bitch.
Stir in your coloring quickly, then, while the liquid is still bubbling mix in your baking soda.
GET READY, THIS STUFF’S GONNA FOAM UP! This is why we wanted the high sided pot.
Once that baking soda hits the liquid sugar, it’ll bubble up to at least twice as high, if not higher.
Immediately pour this foamy mixture into your parchment-lined pan, being careful not to get it anywhere but in the pan. Again, keep in mind this is liquid sugar and it’s 300F hot…use common sense when pouring this out.
Step 3: Chill, Dude...
Once you get it into the pan, leave it alone! Don’t smooth it down! Let it just sit there and continue to bubble and foam and pop. The more you mess with it, the more the bubbles will collapse, leaving you with a dense, boring hard candy.
Again, LEAVE IT ALONE for at least an hour or more while the candy cools and solidifies.
Step 4: Breaking Up Is (not That) Hard to Do
Once it’s completely cool, pull the sheet of cinder toffee out of your baking pan and peel away your parchment paper.
Place the whole slab into a plastic bag and either drop from a height of about 6 inches or strike lightly with the back of a wooden spoon. No matter what method you choose, the toffee should easily shatter into bite-sized chunks.
Step 5: Adding the Chocolate and Black Sugar Crust
Now let’s turn these bad boys into straight-from-the-fireplace embers!
In a microwave-safe bowl, zap your black candy melts for 30 seconds at a time, stirring between each zap (or just use a chocolate pot like I am, either method is fine…all you really want is liquid chocolate at the end.)
It should only take about a minute or so for all the candy melts to completely liquefy and become smooth.
While you’re melting your candy melts, let’s make our black sugar.
Pour the remaining 2 1/2 cups of white sugar into a Ziplock bag. Add a few squirts of your black food coloring and then knead the bag. As you knead, the sugar will pick up the black food coloring. Adjust how much food coloring you add until you are happy with the color.
Pour this sugar into a large bowl.
(*Because I like my cinder toffee extra crunchy, I also added a container of black sanding sugar which has larger crystals than regular white table sugar, but this is purely optional.)
Drop a piece of your cinder toffee into your melted black candy melt. Use a fork to pull it out and gently tap off the excess candy melt.
While the candy melt is still liquid on your toffee, toss it into the black sugar and coat thoroughly.
Pull out of the sugar and place on a piece of parchment paper to firm up.
Repeat with all the rest of your cinder toffee pieces.
Allow all your pieces to cool and the candy melt to harden. The sugar will create a crunchy shell around your candy, leaving you with a black lump that looks almost exactly like a chunk of coal…but bite into it and reveal the brilliant red “ember” center!
Plate up and serve immediately to your favorite naughty list friends, or store in an airtight container for up to a month.
Candy Challenge
First Prize in the
Candy Challenge
