Introduction: Garden Train - Arduino / Wireless DCC
A home made G-scale DMU train runs on brass track around the garden. Unfortunately, the lack of good contact is quite a nuisance to smooth running. To avoid the need for electrical contact, I have converted the train to run off a 6000 maH battery pack (recharger for phones etc).
The DC motor runs around 250 mA so the Lenz standard decoder 10231 at 1 Amp output is fine. I also installed a MRC 1662 DCC diesel sounder in parallel with the 10231.
The transmitter is simply a RFu328 mounted on strip board and a series of push buttons to select functions along with a potentiometer to control speed.
The receiver is another RFu328 that decodes the wireless transmission and converts data into standard NMRA DCC format. It is in fact, small version of my DCC controller (see other instructable).
A small scale DCC booster is included using the SN7544110ne quad h-bridge chip which suits the motor in use.
To get a push-pull output swing of 20 volts (+- 10v), the DCC signal is fed into one input and an opposite, complimentary signal is fed into the other input. The resulting output provides the DCC output for the motor and all functions. More detail to follow
Step 1: Transmitter
The circuit diagram is attached.
Components used:
RFu328 Arduino / SRF wireless module : £16 (Wireless Things Ltd)
AMS1117 step down from 4.5v to 3.3v : £2.55 (ebay)
Push buttons (NO momentary) 10 off : £10.62 for pack of 10 from Farnell
Potentiometer 4k7
3 x AA batteries
On/Off switch and LED
Total cost of components for transmitter, including box, approximately £40
The Arduino code is attached.
send_dcc_via_rf_to_loco_jun2016.ino
Step 2: Receiver
The circuit diagram of receiver is attached.
Components used:
Step up from 5v to 12v at 6 Watt : £3.00 (ebay)
SN754410NE 4 Channel Half-H Bridge Driver IC : £2.30 (ebay)
EasyAcc 6000 mAh Ultra-Slim External 5 volt Battery : £13.99 (Amazon)
Total cost (not including DCC decoders) is around £38
receive_dcc_via_rf_to_loco_jun2016
