Introduction: Grove Hall Sensor - Arduino
After posting a couple of tutorials on instructables, I got a few grove sensors so I thought I would write about it, so the next couple of instructables I will using grove sensors. Seeed Studio has a wide range different sensors, but I will be writing about the most commonly used ones and these sensors will be part of more complex projects.
To start of I'm using the grove Hall Sensor, a hall sensor detects magnetic field and when you take a magnet near it it would send a signal to a micro-controller (in this case we are using an arduino).
So lets get started...
Step 1: Tools and Components
All that you need to get started is
- Arduino UNO
- Grove Hall Sensor
- BreadBoard
- LED
- Jumper wires
The Grove Hall Sensor can be brought form Seeed Studio.
Step 2: Circuit
Now its time to hook up the connections, the connections goes as follows -
- VCC => Arduino +5v
- Gnd => Arduino Gnd
- Sig => Arduino D2
Then upload the code below to check the connections.
void setup() {<br> Serial.begin(9600);
pinMode(2,INPUT);
void loop() {
while(1) {
delay(500);
if(digitalRead(2)==LOW) {
Serial.println("Magnet in range");
else {
Serial.println("Magnet out of range");
}If everything went fine you should have "Magnet out of range" outputed in the serial monitor and "Magnet in range" when the magnet is close to the IC.
Step 3: Control and LED
In this step I'm going to show you how to control an LED, such that when you bring a magnet close to the Sensor the LED will glow.
Connect the anode of the led to digital pin 6 and the cathode to Gnd.
After connecting the LED upload the code -
void setup() <br>{
pinsInit();
void loop()
if(isNearMagnet())//if the hall sensor is near the magnet?
turnOnLED();
else
turnOffLED();
void pinsInit()
pinMode(HALL_SENSOR, INPUT);
pinMode(LED,OUTPUT);
/*If the hall sensor is near the magnet whose south pole is facing up, */
/*it will return ture, otherwise it will return false. */
boolean isNearMagnet()
int sensorValue = digitalRead(HALL_SENSOR);
if(sensorValue == LOW)//if the sensor value is LOW?
return true;//yes,return ture
else
return false;//no,return false
void turnOnLED()
digitalWrite(LED,HIGH);
void turnOffLED()
digitalWrite(LED,LOW);
