Introduction: How to Select the Correct Drop Down TV Lift
The most recent addition to our line of TV automation products is the TY-05 Drop Down TV Lift. The unit is designed to be installed above the ceiling or against the wall. The lift is operated using a wireless remote and can raise your TV to hide it from plain sight and lower it when needed. In this Instructable, I will be discussing how to select the correct model for your application.
The drop down TV lift comes in the following three models, TY-05-30, TY-05-40 and TY-05-50. In order to choose the correct model, you must consider three important points; TV size compatibility, ideal viewing height and installation size.
Step 1: TV Size Compatibility
The three models come with various size compatibilities that is determined by the mounting hole dimensions and length of travel:
Generally speaking, your TV can be mounted onto the lift so long as your TV’s VESA (Video Electronics Standards Association) standard is smaller than the mounting hole dimensions listed. The VESA standard comes with 2 numbers, for example 200mm x 200mm. The first number is the width and the second number is the height of the mounting hole locations.
Another consideration for TV size compatibility is the length of travel. If you wish to completely hide your TV above the ceiling then the length of travel must be longer than the height of the TV. For example, if you have a TV with a 28” height then choosing the TY-05-30 with a 30” length of travel will be suitable. When the lift is fully lowered, your entire TV is visible. When the lift is fully raised then it will travel a total of 30” upwards, thus completely hiding your TV. If you have a TV with a 34” height, when the lift is fully lowered you will have the top portion of the TV still hidden above the ceiling.
The exception to sizing based on the travel length is if you do not wish to fully hide the TV above the ceiling. For example, if you are mounting the lift against a wall without anything covering the TV as it raises and lowers. For this you simply choose the travel length you require.
Step 2: Ideal Viewing Height
Now that you know the minimum size you need for your TV to be compatible, it is time to decide if you need a longer length of travel in order to achieve your ideal viewing height. For example, even if your 55” TV can fit in a TY-05-30, you may want to choose a TY-05-50 to get a longer length of travel. An example of this would be if you have a high ceiling and you wish to lower your TV down to eye level. This can be seen in the diagram below.
Step 3: Installation Size
Once you have chosen the best lift model based on the TV size compatibility and ideal viewing height, the final and arguably most important step is to ensure that you have enough space above the ceiling to install the lift. As seen in the Model Length Comparison diagram above, each lift has a different length of travel and fully raised length.
The fully raised length determines the minimum vertical space required to install your lift if you wish to have the bracket at the bottom of the lift level with the ceiling when fully raised. This bracket is designed for you to mount a cut-out of your ceiling so that when fully raised, the lift and TV are completely hidden. This bracket can be removed if you do not wish to add a ceiling cover.
If you wish to stop the lift before it reaches the fully raised position, for example if you have a ceiling cover that you want to be in-line with the ceiling, then you can use the External Limit Switch included. This button stops the lift from raising further once it is pressed. You simply mount it in a way that it is pressed as you reach your desired stopping point. Keep in mind that by stopping the lift before it reaches the fully raised position, you are reducing the travel length.
Step 4: Conclusion
We hope this Instructable helps you in choosing the best TY-05 Drop Down TV Lift model for your application. If you have any questions, please feel free to call us at 1-800-676-6123 and our engineers will be more than happy to assist you.
Follow Us on Social Media!
Twitter - https://twitter.com/ProgAutoInc
Facebook - https://www.facebook.com/ProgressiveAutomations
Google+ - https://plus.google.com/+ProgressiveAutomationsIncRichmond
