Introduction: Install 20W Cube LED Pod Lights on 2016-up Toyota Tacoma
This tutorial will show you how to install the 20W CREE cubic LED pod light set for the 2016-up Toyota Tacoma. After installing these cube LED fog lights, your Toyota truck will achieve improved lighting capabilities as well as enhanced style.
*Please note that there will be some drilling involved in this installation process.*
Step 1: Remove the Stock Fog Lights.
Open the wheel well to reveal your working area. Unplug the stock harness from the fog lamp. Remove the OEM fog lamp and the front bezel.
Step 2: Put the Shield Over the Mounting Location.
Mark the drilling locations through the holes of the shield.
Step 3: Once You Have Finished Drilling the Mounting Holes, Bolt on the OEM Fit Mounting Bracket.
Step 4: Bolt on the Shield.
Use the included screws, plastic washers, and metal washers to secure the shield.
Step 5:
Preassemble the cube LED fog light. Insert the LED pod light from the front and secure it to the OEM fit mounting bracket from the back end.
Step 6: Connect the Wires to the Stock Harness Using the Included Pigtail Connectors.
Repeat steps 1-6 for the other side. Test your cube LED fog lights to make sure they lights up. Once you confirmed that it does, you can now enjoy your set of cube LED pod lights on your Toyota Tacoma!
Shop for this and more offroad truck LED lighting today!
