Introduction: Jailbreak IPhone 4.3.3
Step 1:Make sure your iPhone is on firmware 4.3.3. (Download from our Download section @ iphonenowunlocked.com)
Step 2: Download RedSn0w 0.9.6 rc16 from our iPhone downloads section. Save it to your desktop.
Also download the iOS 4.3.3 firmware for your iPhone and save it to your desktop as well.
Step 3: Launch RedSn0w and click Browse to select the 4.3.3 firmware you downloaded in step 2.
RedSn0w will ask you if it is a newer firmware or not. Read the explanation and select an answer. In
this tutorial, we will select an older model, but it doesn’t really make a difference. Once you selected
Yes or No, click Next to continue.
Step 4: RedSn0w is now going to prepare the jailbreak data, which should take just a few seconds.
Step 5: RedSn0w will now ask you to select a few options. For this tutorial, we will only choose to
“Install Cydia”, which is the bare minimum. You can also install custom boot logos for example, but
this is just optional. Click Next to continue.
Step 6: RedSn0w will ask you to make sure it is plugged in to your computer and turned off. If it’s
not, follow the onscreen instructions.
Step 7: Make sure you’re ready because RedSn0w will give you a few instructions to follow in order
to enter DFU mode.
Step 8: If you successfully enter DFU mode, RedSn0w will now jailbreak your iPhone. You should
see a bunch of funny code displaying on your iPhone, then you should see a pwnapple. It’s all good,
relax and let the magic happen.
Step 9: Once done, your iPhone will reboot by itself. You should now have a jailbroken iPhone with
Cydia installed.
Congratulations, you just jailbroke your iPhone in just a few minutes.
