Low Gravity Growth Chamber
I have designed this growth chamber for use in space. It uses fusion 360, which I use as a student. it incorporates light which are spaced evenly throughout the chamber so the plant grows into all the available space so that there is more plant for less volume
Teacher Notes
Step 1: The Base
For the base, I wanted to have a good use of the space allowed. This meant using a square frame with a hole made for a water tank (step 2) and soil. It also needed a hole for a water hose (5 mm) and it would in a future time have a hinge for the lid.
Step 2: The Water Reservoir
The water tank is a formed object which has a hole that lines up with that on the base. it is a sort of cuboid to maximise volume as well as being only 1 mm thick.
Step 3: The Water Pipe
As this will be used in micro-gravity, I do not need to use a pump for the water; it will float up the tube and into the air around the plants anyway. The total diameter is 5 mm, do it can just be inserted into the hole and glued in place.
Step 4: Lid
To leave room for the hinges and clip, this part will be only be 38.5/40 cm high. It would made of clear acrylic and have small 0.5 mm holes for air intake. attached to the insides, in a 3D grid, would be LEDs, attached to a battery, with heat shrink over the connections. this would encourage the plants not only to grow upwards, but to grow out, down and in between as well.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
