Introduction: New Life for a Broken Screen Android
Anyone who is faced with the damage of the screen of your android by hit or other cause, will discover that its repair is very expensive (generally between 70 or 90% of the value of the equipment) so most of us choose to buy a new and improved device. Once we have overcome the charm of the new device, we ask ourselves: how to use that old device with the broken screen ?. There are many tutorials to reuse old androids , but the main problem for us will be: how to interact with our devices if we can not see anything or almost nothing of what happens on your screen?
Cualquiera que se halla enfrentado a el daño de la pantalla de su android por golpe u otra causa, descubrira que su reparacion es muy costosa (generalmente entre el 70 o 90 % del valor del equipo) asi que la mayoria de nosotros optamos por comprar un nuevo y mejorado dispositivo. Una vez superado el encanto del nuevo dipositivo nos preguntamos :¿ como darle uso a aquel antiguo dispositivo con la pantalla rota?. existen muchos tutoriales para reutilizar androids juvilados ,pero el principal problema para nosotros sera:¿ como interactuar con nuestro dispositivos si no podemos ver nada o casi nada de lo que pasa en su pantalla ?
Step 1:
for this project I use a Woo SP Quasar Chinese telephone with android 4.2 but the steps I follow will be applicable t for any android device, especially models higher than Android 4.2, if the touch has survived the damage, or we can see some fraction of the screen.
for example, adapting our android to its new uses ,will be easier if your device includes hdmi or Mini hdmi output with this we could see your screen by connecting it to any monitor or tv that receives this type of connection
therefore the worst possible device would be a very old android with its useless touchscreen, totally black screen and without usb support
Aunque para este proyecto use un tefefono chino Woo SP Quasar con android 4.2 las pasos que sigo seran aplicables en cierta medida para cualquier dispositivo android, en especial modelos superiores a android 4.2 , si el tactil ha sobrevivido al daño , o podemos ver alguna fraccion de la pantalla.
por ejemplo adecuar nuestro android a sus nuevos usos sera mas facil si tu dispositivo incluye salida hdmi o Mini hdmi con lo cual podremos ver su pantalla al conectarla a cualquier monitor o tv que reciba este tipo de conexcion
por tanto el peor excenario posible seria un android muy antiguo con su tactil inutil su pantalla totalmente negra y sin soporte para dispositivos usb
para todos los otros dispositivos lo mejor seria lograr tener un escritorio remoto via usb al pc o wifi a un smart tv .
para operar visualmente
Step 2: Like a Blind Person
If we investigate how blind people use their phone or tablet we will discover that they manage to do a lot of things: call by phone, listen to music, do mathematical operations, surf the internet, video games (like A blind legend) etc, etc, all this without seeing anything in his screen . Therefore, if we want to interact with our android with daily use, it would be useful to install this type of applications to facilitate the interaction with it (not so, if we want to convert it into a security camera or web server)
The good news is that there are several assistive technologies installed in our phones such as Talkback that when activated will read the page in which we are what it contains, everything on which you put your finger and activate it with a fast double clicks. also pop-ups
Si investigamos en como usan las personas invidentes su telefono o tablet descubriremos que logran hacer un monton de cosas: llamar por telefono, escuchar musica, hacer operaciones matematicas, navegar por internet,video juegos(como blind legend) y un largo etc , todo esto sin ver nada de lo que muestra su pantalla . por tanto , si deseamos interactuar con nuestro android con uso diario , sera util instalar este tipo de aplicaciones para facilitar la interaccion con el (no asi, si deseamos convertirlo en camara de seguridad o servidor web)
https://play.google.com/store/search?q=ciegos&c=ap...
La buena noticia es que existen varias tecnologias de asistencia pre instaladas en nuestros telefonos como Talkback que al estar activado leera la pagina en que estamos lo que contiene , todo sobre lo que se ponga el dedo y lo activara con una doble persion rapida. tambien ventanas emergentes .
Step 3: Activar Talkback
to manage to activate talkback in our device totally in black
we can use 2 methods
The method of screenshots and the comparative method.
by screenshot
on android. You can use the hardware buttons to do this (power + vol - at the same time on my phone). connect the device to a computer. Open in a file manager, find the location where your phone stores screen captures. Take a screenshot on your phone. See the updated screenshot. By doing this, you can perform an action on Android, take another screenshot and see what screen appears. After doing this for a while, you should be able to find the Setup menu-- accessibility --- talkbakc
Comparative method
A bit more difficult is to use a device like ours to replicate the movements at the same time to give us an idea of what we are doing in our device. if we do not have an equal phone or similar menu we can use our same version of android mounted on a virtualbox machine
more information: https: //support.google.com/accessibility/android/a ...
para lograr activar talkback en nuestro dispositivo totalmente en negro podremos usar 2 metodos
El metodo del las capturas de pantalla y el metodo comparativo.
por captura de pantalla
en android . puede utilizar los botones de hardwarepara hacer esto( power+ vol - a la vez en mi telefono ) . conécte el dispositivo a una computadora. Abra en un administrador de archivos, encuentra la ubicación donde el teléfono almacena capturas de pantalla.Tome una captura de pantalla en el teléfono. Mire la captura de pantalla actualizada. Al hacer esto, puede realizar una acción en Android, tome otra captura de pantalla y ver qué pantalla aparece. Después de hacer esto un rato, usted debe poder encontrar el menú de Configuracion-- accesibilidad---talkbac
Metodo comparativo
un poco mas dificil consiste en usar un dispositivo igual al nuestro para replicar los movimientos al mismo tiempo para darnos una idea de que cosa estamos haciendo en nuestro dispositivo. si no disponemos de un telefono igual o con menu parecido podemos usar nuestra misma version de android montado en una maquina virtualbox
mas informacion :https://support.google.com/accessibility/android/a...
Step 4: Pantalla Compartida O Remota
Of course the greatest convenience we will find when achieving a remote screen or shared screen. If our device has a physical output of HDMI it is a question of only connecting it to the monitor or TV. if you do not have it, but if you have the option to share screen, transmit, remote screen (the names change in each device) we can activate it with the aforementioned methods or with talkback if it lacks this service then we should use programs like: wondershare mirror go , viewer, airdroid, or adb activating the debug usb with the aforementioned methods that will vary from device to device.
Por supuesto la mayor comodidad la encontraremos al lograr una pantalla remota o compartida .si nuestro despositivo tiene una salida fisica de hdmi es cuestion de solo conectarlo al monitor o tv . si no la tiene ,pero si tiene opcion de compartir pantalla ,trasmitir, pantalla remota (los nombres cambian en cada dispositivo) podremos activarla con los metodos antes mencionados o con talkback si carece de este servicio entonces deberia deberemos usar programas como : wondershare mirror go, visor, airdroid, o adb activando la depuracion usb con los mencionados metodos que variaran entre dispositivo a dispositivo .
Step 5: New Life
Now that we can interact with our phone we will have to choose what use we will give to our old device. some of the most interesting daily uses in which we could convert our android are: replacement telephone with talkback, automation of the house with google home, as a personal assistant with siri or ok google, unfortunately ok google does not work effectively on my phone for I've decided so much to turn it into a media player connected to a wireless speaker that I already had around my house.
The programs that I decided to use are:
jvc smart music control: it is a music player with control by hand gestures and with an application launcher with large icons. It also interacts by voice. is designed for vehicles
vlc.3.1.1 this version of vlc is layers to connect to my pc via wifi via plex server preinstalled in xbmc on linux, which allows me to access the hard drive of my pc located on the 1st floor and play on my speaker in the workshop on the 3rd floor.
opera mini: although there are several applications to listen to streaming radio most of them failed after a few seconds (I do not know the reason and must be due to my phone) the best solution to listen to internet radio for my a mini operation. streaming in quick access or favorites.
Ahora que podemos interactuar con nuestro telefono deberemos elegir que uso le daremos a nuestro antiguo dispositivo. algunos de los mas interesantes usos diarios en que podriamos convertir nuestro android son :telefono de repuesto con talkback, automatizacion de la casa con google home ,como asistente personal con siri u ok google ,lamentablemente ok google no funciona de manera eficaz en mi telefono por tanto me he decido en convertirlo en un reproductor de medios conectado a un parlante inalambrico que ya tenia por mi casa .
los programas que decidi usar son:
jvc smart music control : es un reproductor de musica con control por gestos de la mano y con un lanzador de aplicaciones con iconos de gran tamaño .tambien interactua por voz . esta diseñado para vehiculos
https://apkpure.com/es/jvc-smart-music-control/com...
vlc.3.1.1 esta version de vlc es capas de conectarse a mi pc via wifi por medio de servidor plex preinstalado en xbmc en linux, lo que me permite acceder al disco duro de mi pc ubicado en el 1 piso y reproducir en mi parlante en el taller en el 3 piso.
https://apkpure.com/es/vlc-for-android/org.videola...
opera mini :aunque existen varias aplicaciones para oir radio en streaming la mayoria de ellas fallaba despues de algunos segundos (desconozco la razon y debe deberse a mi telefono ) la mejor solucion para oir radio por internet para mis a sido opera mini.dejando las web de streaming en acceso rapido o favoritos .
https://apkpure.com/es/opera-mini-fast-web-browser...
flexer
Trash to Treasure
