Introduction: Obstacle Avoiding Bot Using Ultrasonic Sensor and Arduino
About: We provide services in Embedded Projects, Website Development, App Development, Customised Electronic Solutions and Products
In this tutorial we are going to make an obstacle Avoider Bot using Ultrasonic Sensor and Arduino Uno.
Components Required –
Arduino Uno – https://amzn.to/33U9phD
Ultrasonic sensor – https://amzn.to/2OULNoC
L298N Motor Driver – https://amzn.to/2qwAGZW
2x DC Motor – https://amzn.to/34SjU6i
Chassis – https://amzn.to/2s5c3Uh
Jumpers – https://amzn.to/33VssIn
OR
Buy it from Alpha Electronz - Instagram | Whatsapp | Facebook
Step 1: Ultrasonic Sensor
An ultrasonic sensor is an instrument that measures the distance to an object using ultrasonic sound waves.To know more about Ultrasonic sensor Click here
Step 2: L298N Motor Driver
L298N Motor Driver Module is responsible for providing the necessary drive current to the motors of the robotic car.
Step 3: Circuit Diagram
The connections of Motor Driver and ultrasonic sensor is given in the above circuit diagram.All the components are attached on the chassis.After all the placement your Bot should look something like this.
For further help on Placement and connecting Everything See the full tutorial Video at the end of the post.
Step 4: Code
Obstacle Avoiding Bot using Ultrasonic Sensor and Arduino Uno.
Date - 6/12/2019
Website - <a href="http://alphaelectronz.com">http://alphaelectronz.com</a>
int trigPin = 3;
int echoPin = 2;
int m1 = 5;
int m2 = 4;
int m3 = 7;
int m4 = 6;
int s1 = 10;
int s2 = 11;
void setup() {
Serial.begin(9600);
pinMode(m1, OUTPUT);
pinMode(m2, OUTPUT);
pinMode(m3, OUTPUT);
pinMode(m4, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
analogWrite(s1,170);
analogWrite(s2,170);
void loop() {
long duration, distance;
digitalWrite(trigPin,HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration=pulseIn(echoPin, HIGH);
distance =(duration/2)/29.1;
Serial.print(distance);
Serial.println("CM");
delay(10);
if((distance<15))
digitalWrite(m1,LOW);
digitalWrite(m2,LOW);
digitalWrite(m3,LOW); //
digitalWrite(m4,LOW);
delay(1000);
digitalWrite(m2,HIGH);
digitalWrite(m4,HIGH);
delay(500);
digitalWrite(m1,HIGH);
delay(700);
else if(distance>15)
digitalWrite(m3,HIGH); //HIGH
Step 5: Conclusion and Output Video
Note – Possible Errors due to which your bot is not working properly.
  • Check the voltages of both batteries.
  • Use 2 batteries for Motor Driver and 1 for powering Arduino.
  • Check all the connections once again
If you have any doubts or problems regarding the code and circuit. Feel free to ask in the comments section.Or contact us on Instagram | Whatsapp | Facebook
