Introduction: Perfect Chocolate Covered Strawberries for Valentine's Day
While chocolate covered strawberries are one of the most decadent and delicious chocolate treats - they can be somewhat tricky to make. Here's how to easily make chocolate covered strawberries at home. Get creative with the toppings - Try nuts, sprinkles, and different colored candy melts for a flare. Have fun and enjoy!
Check out the tutorial above!
You'll Need:
Fresh Strawberries
Mini Chocolate Chips
1 tsp. Oil
Parchment paper or plastic wrap
Plate
Paper Towel
Optional: White Chocolate, Sprinkles
Step 1: Prep
Pick the freshest, prettiest strawberries from the bunch and give them a rinse and soak for at least 10 minutes. The soak will help to remove any pesticides from the berries.
Place the berries on paper towel to dry and pat each one individually. Allow to air dry for at least 5 minutes. The drying is probably the most important step so make sure they're completely dry.
Step 2: Melt Chocolate
Use or make a double boiler by putting your chocolate and oil in a glass or metal bowl. Fill a small pot with water and bring to a boil. The bowl should sit on top of the pot without the bottom of it touching the boiling water.
If this isn't an option, melt the chocolate in the microwave until melted, while stirring every 30 seconds.
Step 3: Dip and Sit
Prepare a plate by lining it with plastic wrap or parchment paper.
Using a toothpick or fork, stick the strawberry through the top and roll in the chocolate. Allow any excess chocolate to drip back into the bowl. Carefully lay the berries onto the plate.
Complete those steps for every berry.
Step 4: Dip and Decorate
For chocolate chip strawberries:
After dipping the berries in chocolate, immediately dip into mini chocolate chips and roll until fully covered. Lay on a parchment lined baking sheet. Refrigerate the berries for 30 minutes or until the chocolate has fully set.
Step 5: Done
Finish bare berries with a white chocolate drizzle or candy melts.
For Valentine's Day, I like to drizzle the berries with pink candy melt.
Place each berry in a cupcake liner to serve.
Hack Your Day Contest
Valentine's Day Challenge 2016
Meal Prep Contest
Chocolate Contest
