Introduction: Phosphorescent Keyboard Barcelet
Have you got run-down keyboard? It isn't a trash. You can make an interesting barcelet from it.
Step 1: Step 1: Tools and Materials
You need: Tools: Drill, Drill-bit diameter=1mm, Tape, Toothpick, Wire, Bail
Materials: Phosporescent paint, Keyboard buttons
Step 2: Step 2: Measure and Choose You Text
Measure your joint circle and add 2 centimetres for it .Calculate how many buttons you need. (circle/weight)You need so many stave as many as the upshot-1. :) So, number of your staves: joint circle/button widht-1.
For example:circle=18cm, weight=2cm -->18:2-1=9-1=8 I need 8 buttons. You don't need as many as me.
After this you must choose your text.
Step 3: Step 3:Drill
Drill holes. Diameter=1mm. Drill holes for every buttons, to the corners.
Step 4: Step 4: Make the Anchors
Make anchors by wire. The wire doesn't need to be too strong but it doesn't need to be too woozy. Use the bail for inflection. How can you do this? Look at the pictures. :)
Step 5: Step 5: Union
Trifle sway out the anchors and put them into the holes . Repeat it until you finish barcelet. Don't put anchor to the last and the first holes.
Step 6: Step 6: the Snap
Step 7: Step 7:Paint
Use te toothpick for paint the caracters. Paint the caracters. Wait until it will be dry.
Step 8: Finish!
Your barcelet is ready for use. :) It can light in the dark.
