Introduction: Pinebox Portable Computer
This is a multi-part instructable for a Portable Raspberry PI computer and development system:
It's a Pi, in a box, a box made of pine, hence the name: PInebox!
Uses:
- Portable Linux computer/laptop
- Raspberry Pi hardware/software project development platform
- Backup emergency PC (web browser/email)
- General 5 Megapixel Camera/HD Video (with audio)
- Portable Audio recorder/player
- Remote ZoneMinder CCTV camera source and ZoneMinder CCTV camera montage monitor
- DVB-T2 television receiver?
- VOIP/Skype phone?
- And more!
Step 1: Specifications
Hardware spec :-
- Raspberry Pi 2 Model B, Quad core ARM, 1G memory
- HD Screen from Cyntech (HDMI 1280 x 800, LED backlit)
- HD camera (front, side and rear) with 2 x LED flash
- Wired and WiFi network access
- 8G system/OS drive (Micro SDHC 8G/Noobs)
- 16G internal onboard storage (USB stick)
- Full size keys, compact keyboard (wired)
- Wireless Mouse LIRC (Infra Red control) Transmitter and Receiver
- Audio Out: Headphone (ext)/Speakers (int)
- Audio In: Line In (ext)/Mono Mic (int)
- Approx 55WH battery pack and internal charger
- Flexible recharging/external power requirements
- Custom wooden case
Ports :-
- 2 x USB
- 1 x RS232C (D9)
- 1 x Wired network (RJ45)
- Universal AC/DC In (2.1mm DC jack)
- 2 x Audio (line in/spkr out) (3.5mm jacks)
- 40 way GPIO with boosted (i.e. non Pi powered) 3V3/5V supplies (internal)
Step 2: Concept/Design
After lots of paper scribblings and sketching, physical layout for this project was mocked up in Blender 3D for checking sizes, clearances, and to give cutting/marking guides. The attached video is rendered from the Blender model to give an exploded view.
I took photos and flatbed scans of the actual hardware, to be used as textures onto accurately sized boxes in Blender, and downloaded photos and measurements for the HDMIPi screen/HDMI controller (which I didn't physically have at the time).
Various boxes were added to the flat PCB modules for marking upstanding components (e.g. connectors) that could interfere.
I imported the STL file of the Camera Spinner into the Blender model.
The final design differs slightly from the concept pictures/video shown here.
- The whole box and screen surround is slightly wider
- The camera, flash, and LIRC module were moved further down the case
- DC-DC Converters both in the base unit now - there was one in the lid originally
- Two clasps were used (left and right) instead of one (centred)
- External friction stays added to keep the screen upright
Major components are picked out in the image comments above.
Step 3: Subproject Links
Here are all the parts of the project so far, and placeholders for those to come!
Screen:
HDMIPi screen original assembly video and extra build notes and mods
Camera:
Camera spinner provides HD/5Mp front/rear/side camera for stills and video
Macro adapter to allow camera to focus closer for detail
Electronics:
Power And Control PCBs Design Using LTSpice to simulate/prototype, EagleCAD for layout
Power And Control PCBs Build To give power supply, battery charger/monitoring, power saving, camera handling, LIRC port, RS232 port and lots of other useful interfacing.
Wooden Box:
Hinged case for project, a mitred box with splined corners.
Upper framework to mount HDMIPi (Screen), Raspberry Pi and camera
Lower framework for keyboard, ports, speakers, power PCBs, batteries.
Logos for inside and outside
Build:
Final assembly of all the parts into the case
Software:
Rapid setup/customise of Pi checklist (to be updated with latest Raspbian)
Custom Python software for power and control boards/camera spinner boards.
Step 4: Latest Progress June 2015
All major components fitted into the bare (unpainted) case, with a temporary lash up of batteries/DC-DC converter. It can go battery powered (but with no internal charger), and it can go wireless. No expansion/IO ports yet, and no wired network. Camera spinner and manually activated flash works.
Step 5: Latest Progress July 2015
Disassembled to finish case off and do painting/staining, pending finishing up the custom PCB designs.
Step 6: Latest Progress September 2015
Finally finished tweaking and writing up all the electronic design parts for the PCBs, which are being made!
Step 7: Latest Progress December 2015
All boards built, tested and schematics/LTSpice files added to the Electronics Build instructable.
"Backup emergency PC (web browser/email)" feature unexpectedly tested and found working when I was put off-line by my firewall machine failing just before Xmas. :( Thank you Raspberry PI! -- still mounted on a piece of MDF :)
Step 8: Latest Progress February 2016
All parts finally fitted into the case!
Still to do :-Custom software bits.
