Introduction: Polymer Clay Cosmic Cupcake
Hiya guys this is my first instruct able please be friendly comment and follow if u liked it please!! You can request for more vids!!
Step 1: Things You Need
Polymer clay Blade or exacto TLS (translucent sculpt clay) Toothbrush Toothpick (Optinal) eye pin
Step 2: Base
For the base of the cake take your light blue clay and form a flat cylinder you can tweak this part as much as you want add texture to the base with a toothpick
Step 3: Cake
To make the cake make a flat circle with white clay again you can tweak the disign it should look something like the pic texture this to look like a cloud with your toothpick and toothbrush
Step 4: Attach
This is the easy part secure the top to the base tada!!
Step 5: Frosting
For the frosting add TLS with some chalk pastels if you don't have that you can use little pieces of clay I'm adding pink blue and purple then add the mix to the cake top
Step 6: Sprinkles
To make sprinkles take pink and blue clay roll then out and cut for cute little sprinkles!! I'm also adding yellow for stars
Step 7: Bake
Bake at 250 degrees for about 20 minutes
Step 8: Finished!
Now you can glaze it or use clear nail polish and tada!! You are done!!
