Introduction: Precision Farming
this project is used to control the level of the water in a tank.it is also used to determine the moisture in a soil and control the speed of drip irrigation system in a tank.it is also used to determine the temperature and humidity of the surrounding air.all these parameters display on LCD.when the water level is little then the pump is on and buzzer is on to indicate the water is little in a tank
Step 1: Pcb Layout
first we design the layout of PCB in dip trace and then print on glossy paper with the help of printer to print on the PCB.
Step 2: Pcb Fabrication and Etching
place the layout on pcb and pressed it with the help of press.and etching it with tthe ferric chloride and after etching
we remove the printed circuit and get the conducting plate
Step 3: Drilling and Soldering
after etching make the drill on pcb and place the component and soldering it
Step 4: Make the Water Sensor
again same procedure to make the pcb of water sensor
Step 5:
place the drip irrigation system in a plastic jar
Step 6:
place the pump in bucket to supply the water and supply in a plastic jar
Step 7:
finally start the precision farming and observe that how it is precised for the agricuture
Step 8: Arduino Code
- the arduino code is
Step 9: Live Demonstration of Precision Farming
this video is to show the working of project
