Introduction: R/C Coreflute BIPLANE!
Im a tinkerer and a thinkerer and i cant ever stop working with my hands!
So i've been amazed by R/C since i was little and could never sum up the courage to tinker with aircraft.......
So one day I bit the bullet and bought a trainer and havn't looked back!!
I've scratch built 3 quads and a hex using ARDU pilot in all versions avilable and wokong,
APM is the easiest to use by far and have covered distances of over 10km round trips,
I absolutley love R/C aircraft and my current flier is a x-83 flyjet pushing 120km/p +I've made this instructable to
share how easy and cost effective it is to create something fly worthy and most importantly EASY!LETS GO!!!!
**ive had multiple questions over this instructable which is a revamp of my old thread, YES! it did fly, quite well for a period of months, eventually i replaced the brushless with a bigger one causign half the plane to rip from the front, its all tucked away in the rafters under my house looking down upon all my quads on the work bench.
My greatest build so far,
**Alright just an update**
This build is a budget build, everything was purchased at hobbyking for only dollars, nothing including the rx was over $8 AUD, if I needed to make something I did, I used 6 sticks of hot glue and when something broke I fixed it with more hot glue, the orange rx is a budget rx, I've used the 5.8ghz system in multirotors and pylon racers, one of the most underrated bits of gear out there!
Step 1: Materials
Soooo, this Biplane is constructed soley out of Coreflute and Hot Glue,here a breif list, -600x1000 3mm Sheet of Coreflute (any colour)-Hot glue gun and glue sticks-hobby knife/card board cutters-patience-creativity-3 x 5g servos-servo wire x 2-motor and propeller (choose your own)-reciever (again choose your own, i run spektrum)thats pretty much it!, everythign else finiky you will have in your workshop!
all the radio gear is hobbyking and i highly reccomend using all orange RX gear!
Step 2: Components
Now the majortity of this build is touch and go or guess and cut!
I've only ever built one of these and it flew reasonably well after alot of fiddling and changing ,You want a 600mm wide wing surface area and the body to be as slim as possible but still fit in your servos, battery and reciever
this also has caused me a great number of requests, i basically built this thing in an afternoon as a project, i measured everything by eye and pieced it all together, apologies!
Step 3: Guesstimation
so nows time to guesstimate, i like to have a rough idea of how the layout will look before i decide anything, i know from previous build tht biplanes like to be very short in the fuselage and very straight on the wings, coreflute does have alot of flex but this only help the plane fly slower and stabler.
Step 4: Body Construction
So sort out what shape body or fuselage you want, i usually run with a tapered to the rear approach which i think looks nice and works well. a few dabs of hot glue and some sealing beads of glue tie the hole body together,im also one for support braces and use as many as i can fit!
Step 5: Engine Mount
Now i love love love electric, ive used a nitro but electric is just the way to go in my opinion!Im using a turnigy 2000kv brushless motor with a master airscrew 9x5 prop.
This little power plant has huge power and will easily pull verticals form a little plane.The motor comes pre installed witha tiny heat sink which only took a matter of second to file down some wood and hot glue it in the brace slots.Be creative with the engine mount as you probably wont have the same as me :)
Step 6: Tail
Coreflute is such a versatile medium to work with, and as such i;ve found a simple way to make control surface hinges. just simply only cut through one side of the coreflute and trim the edges back, easy peasy!hopefully it makes sense
Step 7: Ailerons!
DONT DREAD THEM!, they make flying so much more enjoyable and controllable, SO SIMPLE TO MAKE!,
i already had a servo setup lying in my box of parts, with micro hinges, but none the less the same diy hinge was used where i only cut one side of the coreflute,
i noted out 1 hole either side of the fuselage for the servo control arms to poke out and couldn't be happier with the result!!
Step 8: SERVOOO CRAZYYY!!!
Servo time!!!, just make sure you center the servos FIRST!!!!I quickly and easily knocked up 2 control rods and hot glued the servos straight onto the fuselage, easy peasy and took all of 5 minutes!
Step 9: WING TIME!!
this is where you need a wingman !, no not really but it helps to have someone help line everything up while you glue,i used 4 vertical mounts which i then braced on the bottoms!,2 at the leading edge of the wing and 2 at the rear nice and balanced!Once everything looks striaght go over the joins again with a little extra glue
Step 10: Radio Gear
The engine is simple just push on your mount and 1 screw holds that baby tight on there!, ESC or Electronic Speed Controller is just a little baby 20A kit and one dab of hot glue keeps him just behind the engine!
Receiver------ probably the most critical and cruicial part of the build is the receiver, i use a spektrum DSM2 2.4ghz digital 6 channel receiver and have never ever encounted a problem, absolutley astonishing value for money!pop him in there and test all your servos and set them up as per how you usually fly, detailed instructions are available through google for specific transmitters, i run a spektrum DX6i
UPDATE - upgraded reciever to 9xr hobbyking turnigy gear,
and organe reciever,
Step 11: Finished
CHEAP and EASSSYYYY did i say cheap and easy, my total cost was $8, only including glue, and a new motor, everything else i had on me but the total cost without a transmitter or reciver is UNDER $20thats right!
$20Happy flying i hope you enjoyed this instructable, the biplane currently sits in my shed having flown a spectacular maiden flight of over 6 minutes before the lipo ran out!very stable in the air and very very slow!><
Tech Contest
